Question on leaf spring?
I have 02 FE3 z51, upgraded C6 z51 sways, Bilstein B6 shocks, question is will just upgrading to a rear z06 leaf spring make a difference in handling? Thanks
Anyone?
Originally Posted by Silverwolf_pup
(Post 1599387031)
Do you have enough tire to utilize that much spring/bar/shocks?
Originally Posted by VFR RC46
(Post 1599395412)
(Post 1599397255)
I have the stock factory size tires. Why?
(Post 1599399065)
That doesn't say much (all season, summer, track, etc?) , but it sounds like those tires would let go before loading up your suspension.
Tires and swaybar will probably yield a better result.
Sticky and stiff..........woops |
A Z06 spring is stiff. The Z51 spring is in between Z06 and standard. I think the Z06 spring would over-steer. That is when the back end wants to get in front of you when you loose traction.
Personally, for traction, I want the softest spring I can get away with. Plus, when you accelerate, you get more squat and more traction with the softer spring. I purposely use the Z51 spring but with C6 Z06 a sway bar but I have C6 Z06 tires. There is an art to suspension tuning. If you search suspension tuning or under-steer vs over-steer there is a lot of information you might find interesting. I think you have a good set-up. |
Originally Posted by Rob 02
(Post 1599404352)
