-   Autocrossing & Roadracing (https://www.corvetteforum.com/forums/autocrossing-and-roadracing-23/)
-   -   C6 Grandsport Track Wheels. (https://www.corvetteforum.com/forums/autocrossing-and-roadracing/4273294-c6-grandsport-track-wheels.html)
cagotzmann 05-12-2019 10:22 AM
I am looking to purchase a complete set of wheels for track days. The car is a 2010 Grandsport.
Do I look for OE Wheels or is there other brands that can take the stress of road course track days.
You can buy OE knock offs but I don't trust these wheels.
Prefer Black wheels to hide the brake dust.
freaknbigpanda 05-12-2019 10:38 AM
Get forester f14 18x11 for the fronts and 18x13 for the rear, thatís what most people run here
mikeCsix 05-12-2019 10:47 AM
Forgestar...
cagotzmann 05-12-2019 02:59 PM
These are wider than factory. No clearance problems ?
Also what tire sizes, factory are staggered with larger wheel dia vs front.
ShahulX 05-12-2019 05:44 PM
same for a c6 z06?
cagotzmann 05-12-2019 09:11 PM
18" all around ? factory is 18" front 19" rear, So what tires to keep the traction control system happy ? front dia tires are less than the front.
Racingswh 05-12-2019 10:14 PM
I have always found as long as you keep the front tires shorter then the rear tires you're fine. I have run at different times up to a 2 inch spread between front and rear with the front being shorter and I have never had any issues.
I happen to run a 315 30-18 front and a 345 35-18 rear and they work perfectly.
cagotzmann 05-13-2019 09:27 AM
No Rubbing issues on the front with much wider tires. Any mods required to fit ? going from 9.5" wheel to 11"
What offset /backspacing spec to use ?
xene106 05-13-2019 10:35 PM
I am also looking into new track rims. Even the OE rims aren't high enough quality I feel. They can bend easy if hitting curbing on corners in track.
© 2019 MH Sub I, LLC dba Internet Brands
