FIC Injectors? Is this correct? 1993 Lt1
https://cimg3.ibsrv.net/gimg/www.cor...7832911407.jpg
Bosh 3 from FIC vs original Multecs. To much difference in high. I'm not sure if the upper o-ring can seal. Tried fuel rail and I can see it the rubber of the ring 50% in and 50% off the aluminum. Thougts? |
I did this. Its OK and sure?
https://cimg7.ibsrv.net/gimg/www.cor...77486530be.jpg Same high https://cimg9.ibsrv.net/gimg/www.cor...f1cd1e510b.jpg A second o-ring |
Below is my 1993 Corvette with FIC Bosch IIIs installed.
They've been in for about 7 months, and they don't leak https://cimg2.ibsrv.net/gimg/www.cor...bcefc39751.jpg I remember they did have 2 O-rings, but they installed no issue at all. |
Thanks!! Installed mine with the two o-ring, did a test drive and all is fine.
Out of curiosity are they noticeably quieter than than the old Multecs?
Originally Posted by 9T3VETTE
(Post 1599397124)
In my opinión they are a little bit noisy than the Multecs, but there is big difference in efficiency and performance from any point of view.
In any case, as Aklim says, you must make an effort to listen to them. |
Aklim is right, you'd have to A/B them to tell. With the hood closed and in the cabin you couldn't tell the difference between these and properly functioning Multecs.
Originally Posted by Eilias
(Post 1599397404)
Gotcha. I had always read that the Multecs were loud but that is pretty subjective.
