Upstate SC preferred vendors?
I am in a bind. I just purchased a 1994 Corvette from an online estate auction with lots of modifications. I could not get it started and had it towed to Chevrolet of Spartanburg on Saturday. They informed me today they will NOT work on it because of the modifications. Can anyone recommend a local repair shop, Corvette specialist or not, to which I can have it towed and repaired? There is a short in the system draining the battery as well as error codes for Mass Air Flow Sensor and the Opti-Spark.
thanks in advance for any assistance! |
You might want to post this question in the "regional" page as well
https://www.corvetteforum.com/forums/southeast-42/ |
I have had good luck with Bradshaw Chevrolet in Greer, SC. I took my '94 there shortly after purchase last year. They had to order a new starter (only because I wanted OEM not Autozone), recommended a new oil pan gasket, new lower ball joints and afterwards I couldn't find fault with their work. I needed a new battery and after showing me the alternatives I chose the "mid-grade" battery and they said that is what they recommend. I hope my experience helps you out, as always YMMV.
