Champion battery good?
Is this battery OK? It is on sale (price real good)
Champion Auto Battery Part #:H6-615CH | SKU :1767520
Since Optima was bought out some time ago, I think batteries in general are a crap-shoot. Longevity of the same brand and model battery in the same vehicles is amazingly variable, even when driven similarly. Buy a "better" quality product and drive on! Best of luck. :yesnod: :crazy2:
Originally Posted by bimmerborn
(Post 1599396678)
https://cimg9.ibsrv.net/gimg/www.cor...833f9d1c9f.jpg |
The best battery, at the best price I've ever had was Exide brand. I get them at Tractor Supply.
Not long ago I did some battery research when needing one. What I learned there are only a couple manufacturers, the largest being Johnson Controls. Most all third party battery sellers are Johnson Controls. With that I began comparing the long list of Johnson supplied batteries. Die Hard, AutoZone, Champion, Napa, WalMart, etc are all Johnson, with same/similar ratings, but with different pricing, different warranties with some. The outcome for me was the WalMart presented the best price and warranty. he other real beauty, is there are WalMarts everywhere, so the warranty actually is of value when traveling. I have had a number WalMart batteries in a number of my cars including 4 Vettes with only one problem on a 3 year old battery. I stopped in my local WalMart and 30 min later left, billed only $.02, which they waved. The most problems with batteries I have had over the years? DieHards and Delcos. That might be coincedence but I had more failures in those brands over others, but key is the warranties sucked. The Delco warranty is pretty much worthless, as replacement was only year 1, after that pro rated. When you consider hiw much mire you paid, you basically pay for your own warranty, when you compare to others. In the end you will find the batteries almost identical, yet price and warranty, and service locations can be the difference!
I would buy the best battery available, not the cheapest.
Originally Posted by Corgidog1
(Post 1599399192)
https://www.cartechbooks.com/techtips/battery/ |
The current crop of batteries at Walmart are made by Exide. The warrantee is 3 years (free replacement), and then 2 years pro-rated credit towards a new one.
Originally Posted by ersatz928
(Post 1599399316)
Yes, Walmart changed to Exide a little while ago.
Originally Posted by gliot1
(Post 1599399147)
(Post 1599399192)
They do make a number of different types. I bought a C7 AGM battery that was in Sears, AutoZone and Advanced Auto under different names. All had the configuration that fits a C7, i.e. recessed posts and a top that fits the large positive terminal power board. They all had the same 760 CCA (cold cranking amps) where the standard OEM battery has 565 CCA. That is 35% more! AGM's do last longer. Get the one that is "On Sale and has the best warranty for the price." Asked the Johnson Controls plant manager conducting our tour about warranty. Their warranty to the retailer is the same. It can vary as it's used like insurance! Some charge more for the battery and give a better warranty for marketing reasons! |
Exide does "make" a good battery, I purchased/sold/warrantied thousands of them. Exide, Delco and Deka were my primary brands I sold through my auto parts stores.
Thing to keep in mind is that even though there's only a handfull of battery manufacturers, they typically manufacture to the particular retail chain's specifications. So an Exide manufactured private-brand labeled battery isn't necessarily going to be the same battery as one with an Exide label on it. |
They are all basically the same. Come from one of about 4 manufacutrers. As for the good, better, best battery all you're paying for there is more warranty. Not necessarily a "better" battery. I'm certain someone is gonna chime in and say there is noticable differences just because one costs more, but thats ok. lol
Thank you all. Got the answer I was looking for. And I learned.
(Post 1599399147)
... The Delco warranty is pretty much worthless, as replacement was only year 1, after that pro rated. ...
(Post 1599399332)
They must gave just changed.....as I posted weblink above...only a couple choices in reality, Johnson or Exide!
As far as the link, you can't believe everything you read on the internet. |
(Post 1599401354)
