C4 corvette 40 spline stub axles bolt in using factory 3 bolts complete assy
https://cimg0.ibsrv.net/gimg/www.cor...ee38019326.jpg
https://cimg1.ibsrv.net/gimg/www.cor...755ba76cd1.jpg https://cimg6.ibsrv.net/gimg/www.cor...97d1b8fe4d.jpg C4 CORVETTE 40 SPLINE STUB AXLES COMPLETE WITH HUBS AND BEARINGS. 40 SPLINE BILLET 1350 MOLY YOKES SIMPLE ASSEMBLY BOLT IN USING FACTORY 3 BOLT LOCATION WITHOUT MESSING WITH IRS. PERFECT FOR MANUAL STREET STRIP RACE CARS. AN OVERKILL FOR ANY C4 BUZZ ME IF INTERESTED HAPPY TO HELP ROB |
….. You left out the most important detail … $$$ ??? …..
Originally Posted by C409
(Post 1599399373)
Hi guys. I havent really worked out fixed price as there was a fair bit of fabrication setup but was looking how much interest this would get as i've done my own C4 vette with this set up. And i could build the same to who ever needs the same. As a rough estimate flanged moly 40spline axles ×2 40 spline moly billet 1350 yokes ×2 ×6 timken bearings 100mm (4") hubs inner knuckle ×2 90mm outer hub ×2 Bushes and shims 6 new bolts. ??? |
Looks like a nice unit at a fair price. :thumbs:
You'l only buy it once😊.
This is stock C4 Corvette 28 spline compared to C7 Corvette 33 spline.
https://cimg1.ibsrv.net/gimg/www.cor...5ce2ff4f51.jpg So on your design the u-joint yoke has internal splines instead of external. Are the yokes also fabricated? How do you keep everything together? Bolt from the yoke side? I would think that a 40 spline is overkill if still using 1350 u-joint, even if using the best ones. Good work :cheers: |
Very nice pieces, but are 40 splines really necessary?
Originally Posted by JoeNova
(Post 1599401059)
The billet yokes are 35 spline jegs yokes machined out to 40 spline There are thick spacers in the rear inside hub to stop the axle sliding out. Also another bush that sits against the yoke pushes on the bearing as the yoke bolt is tighten. |
Which U-joint are you using? I have billet stubs from Summers brothers and steel 1/2 shafts from Denny's. I still go thru spicer solid u-joints every few races turning the needle bearings to dust.
Hey. Same 1350 solid spicers. check the torque settings on the u bolts. If u over torque the caps are pretty sensitive. Less is better. Also adding to that . The angle of the halfshafts. If they are not dead level it plays havoc on the joints. The more angular. The more stress. I fitted a 9" ford housing to mine but kept all d irs the same.. i ran a 50mm 2 metre long pipe thru end 2 end knuckle 2 knuckle thru the 9" housing so that when the rear was at ground lowered level. It was dead straight.. if theres any angle.. as the rear squats its loading up the uni's bigtime vitually trying to shorten the halfshaft.
https://cimg5.ibsrv.net/gimg/www.cor...a4cab6e203.jpg |
Damn, that is nice work on that 9" setup.
https://cimg9.ibsrv.net/gimg/www.cor...910f31898c.jpg
https://cimg6.ibsrv.net/gimg/www.cor...cbfca27889.jpg thanks man. Just didnt wanna hav all the dana issues |
I'm swapping to an 8.8 at some point and likely deleting the C-beam in favor of a full underbody crossmember. It seemed like a way easier option than a 9". Obviously not better, but easier.
Originally Posted by Rob Burich
(Post 1599398488)
https://cimg1.ibsrv.net/gimg/www.cor...755ba76cd1.jpg https://cimg6.ibsrv.net/gimg/www.cor...97d1b8fe4d.jpg C4 CORVETTE 40 SPLINE STUB AXLES COMPLETE WITH HUBS AND BEARINGS. 40 SPLINE BILLET 1350 MOLY YOKES SIMPLE ASSEMBLY BOLT IN USING FACTORY 3 BOLT LOCATION WITHOUT MESSING WITH IRS. PERFECT FOR MANUAL STREET STRIP RACE CARS. AN OVERKILL FOR ANY C4 BUZZ ME IF INTERESTED HAPPY TO HELP ROB interested what are you asking for a set? never mind just seen the price $$$$ I messaged you |
(Post 1599398488)
https://cimg2.ibsrv.net/gimg/www.cor...131af23556.jpg |
Originally Posted by JoBy
(Post 1601257188)
Bearing distance to u-joint seems to be much longer than stock?
https://cimg2.ibsrv.net/gimg/www.cor...131af23556.jpg if u just gonna do the stubs 40spline. You'l have to shorten your halfshafts. Axles are 220mm from flange too end spline due to having another tapered cone bearing there. As u tighten the nut inside the yoke pushes against the bearing sleeve so wheel cannot fall out... i know u understand everything im saying😊 |
Stub axles
(Post 1601257442)
hello mate.. i did my 40 spline axles for my C4. It was pretty straight forward. I threw the standard hubs. I had bigger hubs made cnc machine to 100mm i.d and welded the 3 long hex nuts to the hub. Pressed in 100mm o.d ball bearing and a tapered cobe bearing behind it. This is necessary bcos its gotta tighten up.. also theres another cone tapered bearing on the inside..yoke side.. it maybe betta to email me your address and i can send u pics step by step. I have mine completely done and assembled. Driveable Works beautiful.. if u gonna do the stub axles 40spline. U really gotta do the inner ones too which are full floating 35spline 4340 chromoly. Its just too much too mention. But i think well worth while.. happy too help mate. Bcos not many guys havd done this..
if u just gonna do the stubs 40spline. You'l have to shorten your halfshafts. Axles are 220mm from flange too end spline due to having another tapered cone bearing there. As u tighten the nut inside the yoke pushes against the bearing sleeve so wheel cannot fall out... i know u understand everything im saying😊 i pm you regarding a set |
..... I would like to see a half shaft please …..
..... Soooo … basically no suspension at all ??? …..
