Master Cylinder Flare Type
I was wondering if someone here can confirm the flare type on the 09-13 corvette master cylinder. There is a rumor out there it uses a 37 degree double flare versus a SAE 45 degree like every other car in America. Looking on-line all corvettes use a 45 degree or bubble flare. There are not fittings out there that I could find suggest a 37 degree double flare. Anyone know 100% certain?
TTT, someone’s gotta know.,
Anyone?
Not much help but 37 is an AN fitting
You could call a place like SJM Manufacturing, Inc. (724) 478-5580 and ask them. They make line lock kits and would probably know.
The C5 master cylinder is 12 x 1mm bubble flare on the front port and 12 x 1.5mm bubble flare on the back port.
Originally Posted by KENS80V
(Post 1599455807)
Both fittings are 12 x 1mm ISO bubble flare on the C6 master cylinder.
The C5 master cylinder is 12 x 1mm bubble flare on the front port and 12 x 1.5mm bubble flare on the back port. . Thanks, Dave |
I haven't done this in a while, but NAPA used to carry every brake line made (just for the ends) and you can easily form your own bubble flares.
ISO bubble flare has nothing in common with a 45 degree double flare.
https://cimg3.ibsrv.net/gimg/www.cor...0ab908083.jpeg |
GM mixes the worst of both……..
