Idle Glitch ??
Have only driven my new to me Vette twice, brought it home in the rain and then again to go get state inspection. (dry that day) Has 31,000 miles & well maintained. Now back surgery 3 days ago so it will be a bit before driving it again. Once it is warmed up and when sitting at an idle stopped, it seems every 30 seconds or so to shudder or sorta torque roll to the right (feel it in the seat) and yet no discernible change on the tach that I can see.If the RPM is changing I cannot see it or hear it. As I left the shop I mentioned it to my mechanic and he said maybe clean the TBI and or MAF also. It has no effect when going down the road in any gear when I then sorta found out how quick this car is!! Any ideas/opinions as I seat here recuperating?? Thanks, Dave:shrug:
A bit of "shiver" is normal, check your codes and maybe clean the MAF anyways for peace of mind. If you want to go all the way, plugs, plug wires and maybe a replacement air filter.
These cars are not silky smooth, it's a sports car, you're going to get some feedback. I've driven 2 <1 year old C7's and they also have a bit of a rumble. |
does it sort of seem to cut out for a millisecond but keep on running?
Does it do it after the engine has warmed up? On a cold start the PCM needs time to adapt to the environment.
If you have a Z06, the cam is a little hotter and will always have a little shutter during idle. Higher performance engines don't idle as smooth passenger cars. |
Originally Posted by ncali
(Post 1599402506)
Could be a stuck hydraulic roller lifter.
You may have a broken spring It is also possible that the bearing in one of the rocker arms has failed. You could listen for noises with a cheap mechanics stethoscope. I know that the valve-trains in these cars are kind of noisy any way but a damaged rocker lifter or spring would have a louder metallic sound (like a screw driver tapping on a bench). What year is your car. Some years were prone to certain problems. |
It is a 2001 Vert 6 speed, 31000 miles. Now you have me worried!!
Originally Posted by Dave in Pa
(Post 1599403028)
You may just have bad fuel, dirty injectors or possible fouled plug. There is an ignition coil wiring harness on each side of the engine. If one of them got wet, is loose or corroded it could make the engine want to push to one side. You could check the connectors for corrosion. I'm curious as to why you are not throwing a misfire or knock sensor code. AFIK it was the Z06 LS6 that had valve spring issues not the LS1 base coupe/ vert. |
Thanks a lot for all the advice Rob, yeah no codes at this point. In a week or so when I am able t drive it I will have my mechanic check all the above and we will start a process of elimination I guess. Got all the previous maintenance paperwork organized so now I know what has and has not been done. I will post back what I/We find!! Dave
How long has the gas has been in it?
Originally Posted by Rob 02
(Post 1599403385)
How long the gas has been in it?
It's not good for a car to sit too long Did they mention any modifications?
You may have a misfire going on there...since you just purchased it and not knowing how often the PO drove it you may have a lean misfire...maybe a clogged injector...try throwing some Techron in the fuel tank the next few fill ups and see what happens...this can be MANY things going on...just speculating !!
Is this shudder happening with the AC turned on?
(Post 1599403569)
Originally Posted by C5 Diag
(Post 1599405498)
Originally Posted by Turpid porpoise
(Post 1599405710)
Have you ever owned another LS car? The LS generation of GM V8's have a different firing order than the Gen I and Gen II's prior and it can produce what is at best a 'unique' idling profile, especially if all you've ever intimately been around is LT or anything of that order.
If you have pulled codes (you can do this yourself with the car's DIC. Google it and find the YouTube video), you have no codes relating to the PCM, and the car overall appears to be running right then either (1) the car has some sort of shelf tune you weren't told about (I doubt it with just a Corsa cat back and a K&N filter, since those really aren't power mods and throwing a tune at that wastes money) or (2) at the absolute worst there's some general maintenance items lacking. On my second point for example the car may only have 31K miles and the plugs are rated to 100K but the wires are rubbing and rubber over time deteriorates exposed even sitting in a garage. If deterioration occurs in spark plugs wires it increases resistance = lesser than ideal spark. |
^ Well put.
I was getting the feeling there was something the previous owner didn't disclose. |
I picked up my first C5 with 30K on it this year also and drove it 3 hours home. When I pulled off the exit and stopped at the light I experienced what I think you are experiencing. Thought at first it was going to shutter and die. But it kept going with that same type of rhythmatic pattern you describe. Had me wondering as well. Didn't think it was missing since it probably would have thrown a code and, like yours, it runs fine otherwise. After driving it more and getting used to it I just figure it is the nature of the beast as the vehicle has had no issues. I kind of like it now as it is reminiscent of the old idle 'loping' of previous muscle cars. I probably wouldn't fret about it too much while you are laid up until you are able to get more time behind the seat.
