Transmission is out again
I need to replace my transmission this would be my 4th one. I had one under warranty one out of pocket after that one went bad I got a RPM stage 6 and now that one is gone with less then 20000 miles on it. The car has 647 rwhp super charged. I'm so sick of this I can't stand it. No one knows why it happen and rpm has not been any help just told me I need to get a better one. I really don't want to give them any more money. Does anyone else have a place that I can get a new or rebuild trans for a 2001 auto. Thanks
What are you doing with it? Daily driver duty? Guessing with 650whp you are beating the crap out of it. What is failing? the clutches? Do you have a trans cooler? Need way more detail here.
Originally Posted by 4deatr
(Post 1599407071)
No help but good luck getting all that sorted out. Seems like a real headache.
What's breaking? And under what condition specifically?
I run big hp with no problems. Try Finish Line Transmission. In ILL
Check LS1 Tech,alot of good reference's Good luck. |
I can't help ya with your problem, but if it makes you feel any better, I'm get'n ready to put a new one in mine and it'll probably cost 4x as much as your did. :lol:
Are you running a big stall? Do you have a cooler? I have a RPM level VI at about 550hp/Tq and beat the hell out of it but I needed a separate power cooler to keep it cool mounted under the headlight. From what I've heard heat is what kills these.
Drive it very little don't track it car shows and spirited only. I have a trans cooler everything was done right. I don't know what failed yet it has not be open yet.
Originally Posted by Forcedvert
(Post 1599409668)
What was the failure mode of the other transmissions?
Sorry about your trans
(Post 1599409668)
Good luck |
Sounds to me like something in the trans tune is fubar'd. These things just don't fail on the street 3x because you got on it a little.
Originally Posted by K-Spaz
(Post 1599417467)
Originally Posted by JR-01
(Post 1599417531)
647 rwhp. It lasted 20K miles. I wouldn't expect it to last much longer than that.
When we open it up we will see. I know I will not use RPM that's for sure
What was the failure mode of the other 3 transmissions? Do you have a way to monitor transmission temp?
You have something else going on. I would say it is the tune. No way you should be going through trannies like that
Originally Posted by oharal
(Post 1599419480)
