Eco Mode (cylinder deactivation) not working after tune
So I had my 14 Z51 M7 tuned after putting a SC on it. The tuner has confirmed cylinder deactivation is still on. He uses HP Tuners. I would like V4 mode to still work, has anyone had this issues before and had it resolved?
EDIT: The tuner got in touch with HP tuners and will try another flash of the ECM tomorrow to see if that works. |
Sounds like you just saved $200 on not having to buy the Range AFM disabler ;)
You could get a Ford Focus for the days you worry about your gas mileage.
Originally Posted by The Creeper
(Post 1599408720)
Because most feel it is the AFM that destroys the TC. Most of us try and deactivate it for that reason.
Destroys it in what way
You have 4 cylinders running at speed without combustion, and 4 others pushing them and the drivetrain. Does not sound like a healthy recipe for an engine.
You have a supercharger and a tune, and you still want V4 mode??? :confused:
My 14 I bought new over 5 years ago has never seen V4 mode, and never will while I own it. |
I am not in the know enough to explain it but there are numerous threads about it and what it does to the tourque converter. This is not only a problem with Corvette but also a big problem in the trucks. A close friend of mine had his engine rebuilt due to the a AFM valve failure. Again, there are more threads and discussion on this than you can count. Search for AFM issues or transmission issues and you’ll find them. There’s also a rather large sticky thread on A8 issues and in there you’ll see talk of AFM being a large contributor to it. There are some really smart people on this forum so maybe one will chime in or link some of the threads. Worth the read for sure.
Yes, plenty of threads on the AFM and the problems associated with it. Maybe the fact that the AFM is deactivated is a good thing.
I am on my second 2014 and both have had the V4 / AFM mode disabled, My current is a manual and will never see ECO mode...
This member has a manual - no torque converter folks! No A8 problems for him.
Originally Posted by Flame Red
(Post 1599410488)
still doesn’t make sense, to me at least, why the heck you’d intentionally put a corvette into 4 cylinder mode. Plus I only noticed 1-2 mpg gain with afm active and most of the lt1 engine failures can be traced back to the afm lifters. If you can negate a potential issue by simply not putting a M7 car into eco.... why wouldn’t you? |
Originally Posted by Steve_R
(Post 1599409123)
My 14 I bought new over 5 years ago has never seen V4 mode, and never will while I own it. My thoughts exactly. You put in a supercharger and you're looking for good gas mileage? My M7 never sees Eco mode and it never will. At 70+ mph I still get 24 mpg on Hwy. |
Maybe the parasitic loss from driving the supercharger is preventing the computer from seeing a low load situation. Just a shot in the dark.
When I had my tuned I asked the tuner if he could adjust when v4 came on. He recommended to completely turn it off and mentioned that it's a camshaft destroyer. I can only guess from the constant lifter depressurizing/pressurizing. Anyway, I still get about 28mpg highway and 24 combined with it and over 600rwhp. I don't miss it one bit.
V4
(Post 1599409123)
My 14 I bought new over 5 years ago has never seen V4 mode, and never will while I own it. :party::party::party: |
V4 only hits you in the ECO mode. You are not gaining that much but it allowed GM to make the cut on the mileage requirements. Were it me, I'd forget about it.
Elmer |
I don't miss my v4 after supercharger install, 24 mpg on the highway is fine with me and 610 whp
Lol retarded logic. I supercharged my car, how do i get better mpg?
