Clay bar
Anyone on here ever do the clay bar then a simple coat of wax over it?
Never. Clay bars remove contaminants but usually slightly mar the surface. I never clay unless I am planning on machine polishing afterwards.
I always follow up a clay with a machine polish.
HTH John |
I have yes, I polish afterwards now, before waxing.
So, that's what I was asking. If you clay it then, put a wax job on, is that the best way to go about doing a full detail? What are you guys using instead of clay?
My order of operations is this:
Wash Clay Wash Polish - depending on swirls might need 2 different polishes Then either finish with a wax or do a sealant If you did a sealant then finish that with a wax. |
Apparently an incredibly controversial opinion (which is hilarious to me) but I only clay areas which require it. Great to remove surface contaminates like tar, not something I would ever do blindly to the whole car. Polishing is better and safer and far, far more worth your time.
Originally Posted by endus
(Post 1599411403)
(Post 1599411403)
Originally Posted by TrippleH
(Post 1599410999)
Sometimes, just iron/tar remover is all that you need, not the clay. Feel the paint. Now to prep for a coating and the correct prep for a full detail, only the last step changes. Wash, clay, iron/tar removal sprays, machine polish with Jescar Compound and/or Finishing Polish, then you can either wax, seal, or ceramic coat. Wax every 2-3 months and you may not need the clay done in a year's time. Ceramics last years so I'll go years before I'll do this process over again. |
