Is this normal for an auto box?
Hi guys!
I've been wondering a bit about my transmission : When I'm cruising at 60 I'm doing 3500 rpm, when i let off the gas the revs almost instantly drop to 3.2K . So it almost feels like my converter is still slipping 300 rpm. When I'm cruising at 100 and I go full throttle it revs to 4K, like the converter is slipping again. Is this normal? I've never driven auto's with this kind of power ( and this kind of freedom to play with them *laugh* ) Or what could the cause be? I do suspect the trans is overfilled atm (foaming => less 'pressure' in the converter causing it to slip?). Specs: Rebuilt th350 ( ALTO clutches, transgo street kit, 20-2.3K 10" stall converter JEGS 60402) 3.55 gears in the diff No idea what hp the 350 engine makes - 0-100km/h is currently at 5.4s. |
Sounds like situation normal from what I read.....~300 rpm slip due to converter sounds normal to me.....
I have a 200 r4 trans in my '72, so lockup on the converter at speed, but a th350 does not have that option.... |
https://cimg3.ibsrv.net/gimg/www.cor...5611fe08ca.jpg
https://cimg5.ibsrv.net/gimg/www.cor...f83bf0f08c.jpg its overfilled right to first the L of FULL You can see its foaming too. Best to remove some fluid? |
Originally Posted by mrvette
(Post 1599410372)
Originally Posted by Dusky
(Post 1599410548)
https://cimg5.ibsrv.net/gimg/www.cor...f83bf0f08c.jpg its overfilled right to first the L of FULL You can see its foaming too. Best to remove some fluid? Are you checking the fluid with the engine running and warm after having been put in R,N,D,N,R,P for a few seconds each? Not doing so could give you a false reading. |
Originally Posted by Kacyc3
(Post 1599410875)
there was a th350 with lock up, I believe it was called th350c
SOunds like the nature of a converter with a slight stall. It wont engine brake like a stick would
