Going in for big mods
If people are interested I'll keep this thread updated with all the dyno numbers and how everything goes. I have a 2017 C7 Z06 (Z07) 3LZ A8.
The car will be going to Gp tuning next week for a bunch of mods and they will be listed below. Magnuson TVS 2300 Supercharger Stage 2 cam----Gen V cam kit with DOD delete Johnson lifter upgrade and Katech valley cover and phaser limiter DSX C7 Z06 Fuel system and tap LG Motorsports Superpro headers E85 DSX Flex fuel kit Methanol injection----Alky control kit single nozzle LME LT4 Ported Cylinder heads GEN V 160 Thermostat NGK LTR71X-11 plugs HX Coolant expansion tank IW 18% OD Balancer Afe Cold air intake mighty mouse catch can Corsa extreme exhaust HPtuners Unlocked TCM for A8 https://cimg3.ibsrv.net/gimg/www.cor...63f221062.jpeg |
That sounds like a lot. What HP numbers are you shooting for? What are you doing to the rest of the drivetrain? Will the trans and rear stand up to that?
Originally Posted by SharkgrayVetteZ06
(Post 1599412853)
The car will be going to Gp tuning next week for a bunch of mods and they will be listed below. Magnuson TVS 2300 Supercharger Stage 2 cam----Gen V cam kit with DOD delete Johnson lifter upgrade and Katech valley cover and phaser limiter DSX C7 Z06 Fuel system and tap LG Motorsports Superpro headers E85 DSX Flex fuel kit Methanol injection----Alky control kit single nozzle LME LT4 Ported Cylinder heads GEN V 160 Thermostat NGK LTR71X-11 plugs HX Coolant expansion tank IW 18% OD Balancer Afe Cold air intake mighty mouse catch can Corsa extreme exhaust HPtuners Unlocked TCM for A8 Looks like it’ll be a fun build. What cam you going with? You doing long tube headers and xpipe or just headers? Catted non? my car is BTR stage 2 cam, Johnson lifters, 15% lower, CNC ported heads, DSX flex and aux pump, AFE intake, Mamo ported tb, mm catch can, weapon x HX, kooks 2” lt headers, kooks catted xpipe and Corsa extreme. I didnt want want to go meth and was limited to an E40 tune due to running out of fuel high side. Next round will be Maggie, high side fuel and 103mm tb. |
She's gonna be a beast. Share the before / after #'s.
Sounds like $25k well spent! Keep us posted on dyno results. Beautiful car!
not sure what type of tires you are running, but if you're still on stock run flats you might want to add that to the least of things to research.
(Post 1599412853)
The car will be going to Gp tuning next week for a bunch of mods and they will be listed below. Magnuson TVS 2300 Supercharger Stage 2 cam----Gen V cam kit with DOD delete Johnson lifter upgrade and Katech valley cover and phaser limiter DSX C7 Z06 Fuel system and tap LG Motorsports Superpro headers E85 DSX Flex fuel kit Methanol injection----Alky control kit single nozzle LME LT4 Ported Cylinder heads GEN V 160 Thermostat NGK LTR71X-11 plugs HX Coolant expansion tank IW 18% OD Balancer Afe Cold air intake mighty mouse catch can Corsa extreme exhaust HPtuners Unlocked TCM for A8 https://cimg3.ibsrv.net/gimg/www.cor...63f221062.jpeg I have almost nearly the same set up. I have the ARH 1 7/8's coated headers, CPR 5" custom intake, dual nozzle meth, Katech 103mm TB, 23% lower, and CPRs lowside fuel pump. Made 861rwhp, on E50ish. Made 18# boost on on 80mm upper pulley. The 70mm got us to 22# but had some belt slip. CPR is working on this issue and projects mid 900s at the wheel. You are going to love it. Put 345 Toyos on the rear to get it to hook better. Hope you get the numbers you want. |
Originally Posted by Detroit_Bill
(Post 1599413108)
Originally Posted by gr8del
(Post 1599413146)
I’d be curious how it tunes.
Originally Posted by Maxpowers
(Post 1599413148)
Originally Posted by TSLAVette
(Post 1599413368)
Originally Posted by OG_Pokey
(Post 1599413741)
Originally Posted by AZGASSER
(Post 1599414068)
I am running Toyo r888rs on 19" wheels all the way around. 295 front, 345 rear. They are pretty decent at hooking. Can still break them loose but much better than factory.
https://cimg8.ibsrv.net/gimg/www.cor...744ac95ea5.jpg |
(Post 1599416395)
I was going to suggest the R888Rs as well. I'm running them on 20s myself. THe NT05Rs might be a little better dry, but I think they will be scary af in the rain. Do let us know how they perform for you. I'm most curious about wet weather performance, but I'm guessing you're probably not even going to drive it when the roads are wet.
Those tires are the fronts, the rears are almost 14" wide. I have not had them in heavy rain with pooling water. Just drive smart and you will be OK. Word of caution, these tires are loud. Like to the point I had driving on the highway for more than 30 mins. Would not suggest a road trip with them. It's a trade off for better performance.
Eh. They're certainly louder than the PSSs, but I don't feel like they're THAT loud. I made a 2 hour drive last weekend and it didn't bother me that much. Don't even really notice over the regular road noise of the car, imo. You might have to turn up the volume of your stereo a few ticks but it's far from deafening. Someone also posted in another thread that it makes a significant difference if you don't put them on the front, so that's an option
At highway speeds they can be heard over catless headers and the radio at 1/3 volume. I have two 10” subwoofers that can drown them out but when trying to have a conversation not really fun. Someone else mentioned different front as well. Only 500 miles on the tires so not ready to do that.
We road tripped 3000 miles in the MPSS and could sleep in the car but not with these. It is the steady drone over 65 and worse in concrete vs asphalt. |
(Post 1599422502)
We road tripped 3000 miles in the MPSS and could sleep in the car but not with these. It is the steady drone over 65 and worse in concrete vs asphalt. Thanks for that info.... I may still try them on the rear, but definitely won’t on the front now. I like quiet road trips... I keep the NPP closed most of the time so... drone would drive me nuts. |
