1991 ZR1 torx bolt size
Two bolts stripped out on intake manifold. Took it off to replace spark plug wires. Got the bolts out but need to know the size and any place that sells these.
Jerry’s Gaskets.
Thanks, kind of pricey but what are you going to do? Had to buy a set of original spark plug wires awhile ago. Of course they don't make the correct ones anymore.Found a correct set. $175.00.
Jerry sells the wires for around 80 bucks
You need upper plenum bolts? M8x1.25-25 for those. Jerry should have plenum bolts in both new and used. Jerry uses I believe 11516081 and 11516081-U
https://www.jerrysgaskets.com/bolt-p...ed-90-95-6-5a/ |
That's where I purchased the set for 175.
Originally Posted by rpols7454
(Post 1599453717)
No,LT5 along with the cylinder numbers.
(Post 1599440187)
Gary |
