Help the New Guy Gen 4 Corvette - Idle goes to hell after VE tune
2 Attachment(s)
Ok, so I have been going step by step with my tune after mods. I have done both MAF & VE tuning more than once. After I log and tune my idle goes to hell. Not sure what I am doing wrong. I have started from scratch twice now. Any suggestions would be appreciated.
2009 Corvette LS3 A6 Base 14K Miles: Vararam Snake Charmer CAI, Livernois Motorsports Cam/Springs ect - Stage 2C Intake Lift 224@.050 Exhaust Duration 236@.050 Intake Lift .620" Exhaust Lift .620" LSA 117 Livernois Ported Heads & PFADT Series Tri-Y Long Tube Header & X-Pipe w/Cats HP Tuner Pro setup. Thanks, Jeff |
Not getting answers because there are so many possibilities. Who did the engine work? Was the idle bad before the tune? What does "bad" mean? Do your tunes change the idle? Lets start there.
Originally Posted by jim2092
(Post 1599514295)
Your answers are here.
https://forum.hptuners.com/showthrea...al-Information What adjustments to the tune are you making before MAF and then VE tuning? |
Not sure if you solved the situation but... for some reason, gen4 ECUS run rich briefly after flashing. Don't log/tune off of initial few drives. There was a thread on HPTuners about this but i forget where it was.
Originally Posted by Ahrmike
(Post 1599538800)
Injector temp resets after a flash and takes a little bit to get back to normal values. Some tunes have that table available to be updated as needed, others don’t |
