Timing gear set .005 U/S 92 93 LT1
Hi Guys, Do any members know where I may get a Timing gear set that is .005 U/S for a 1992 Corvette with the Non vented Optispark.Machine shop line bored block and now timing
chain (morse Type) is too loose. Thank you |
Check, with Howard's cams or competition products and comp cams.
There used to be a shop I think called Speed Demon that sold a oversize lower gear for LTx motors. I think it was made by Cloyes. I had one and it helped a little. Maybe try contacting CLoyes?
Originally Posted by RichS
(Post 1599507371)
Originally Posted by Apache 84
(Post 1599508383)
Thanks RichS ,I spoke to Cloyes Tech dept on the phone,and yes they don't make an U/S kit for the LT1 engine, never been required, but he is going to speak with his Dept about my request,as it is likely to happen again.
(Post 1599497830)
(Post 1599497830)
chain (morse Type) is too loose. Thank you Good luck and please let us now what you find. BTW I'm sure you know that you can run at least a single row roller standard gear set if you use an electric water pump to eliminate the w/p drive. |
My parts supplier got me a morse chain ,not sure what it is for ,identical to look at but fits perfect. When measured beside old chain it didn't seem to be much shorter ,but when fitted it is perfect may be a little tight.
(Post 1599568410)
Thx for sharing Apache! If you can follow up with your experience when in use would be greatly appreciated. :)
