Easiest way to remove a big block from a junk car?
Not quite Corvette related but i've found myself in a pickle! I have a 75 Eldorado, I saved it from being cubed a few years ago, thinking it would be a nice easy restoration, it had been parked inside for 20 years so I figured it shouldn't be too hard to get going again. Unfortunately after pulling it out of the dark building I realised the roof had been leaking for 20 years over the car and although it could be saved, it was FAR beyond my means to do so, lots and lots of welding, the windshield frame has rotted out along with patches of the floorpan, combine that with title issues it means this car will never go back on the road. Now i've got 2 days to get rid of it as my storage has come to an abrupt end. What is the easiest way to pull the motor out? a 500ci big block with only 30k miles is far too nice to weigh in for metal and i'm hoping at some point in the future It may find a home in my 71 which will be arriving in a week or two. I don't have a hoist and only have basic tools to hand, i'm thinking of just cutting the front of the car, placing 2 pallets ontop of each other under the sump and dragging it out with a pallet truck? Any other suggestions? Will also be saving as many other parts to sell and fund my Corvette build since, let's face it, a vette is far cooler than an old Caddy. I've got about 2 days to do this before it's getting cubed.
BF Torch + BF Hammer and a flock of emigres.
IF you dont have a lift, that sounds reasonable, Your going to have to be able to get at the bellhousing bolts too so that your not trying to move the tranny, so you may have to cut some of he firewall. You cant rent a lift from an auto parts store? I would think you would have to cut the radiator support and the front cross memeber to do what you want to do or cut the frame and fenders right at the firewall and use a vehical to pull the whole front end away. Remember that big block is going to be around 500+lbs. You are going ot have to have the skids under it before you do any cutting, then you are going to have to get it into a trailer or into a truck....the more I type, the more I would find a crane
First thing I would do is get in there and undo everything that ties the motor ( and gearbox ?) to the car body/frame so it's just sitting on the mounts.
I can hire engine lifting cranes from my local equipment hire place ( think car trailer, generators , light construction equipment , chainsaw type stuff ) |
Probably easier to leave the transmission attached in this scenario. It may well be a 200 4R and even as a core, it has value. Without a lift, it’ll be hard to remove on its own. And potentially messy too.
Sell the car to a pick and pull junkyard, then buy the engine back from them. Or don't, if you don't have a place to put it.
Originally Posted by jackson
(Post 1599499179)
First, ask yourself, "what in the world do you want to do with a 500 cid Caddy engine???" It's not a "big block." It's just a plain ol' Caddy engine that has almost no value. It will never go fast, without massive investment. It will never bolt into anything fun (like a Vette or a GTO). The front-drive turbo 400 tranny is useless in any "normal" application. Call it the way it is: It's junk. Sell the entire thing for $200 and keep your life simple.
Lars |
Originally Posted by lars
(Post 1599499944)
Lars |
(Post 1599499944)
Lars I know lots of people think they are terrible engines but I read this and figured it would be worth a shot? https://www.hotrod.com/articles/hrdp...-engine-build/ 500hp 575lp ft of torque isn't bad even if it ends up costing a bit more in todays money? |
(Post 1599499944)
Lars
Originally Posted by Dazaa Rafae Aman
(Post 1599500569)
It is a very good engine. Good for about 6 cents a lb. Lars beat me to it. Scrap
Originally Posted by Kacyc3
(Post 1599500648)
Wait, its fwd?
. Cant be if it’s a TH400 can it? |
are they really THAT bad that you guys wouldn't consider one for the cost of pulling it out of a car? Bear in mind i'm in the UK, an 8.2 ltr engine is worth owning just for the bragging rights associated with saying you own such a thing....
(Post 1599500753)
I'll stand by my answer. Send it to the junkyard. Odds are, when you are ready to do something with it, you can buy it back. More likely, you will never see it again. You win either way! The best car transaction I ever made was one I gave away. |
Originally Posted by CA-Legal-Vette
(Post 1599500727)
https://cimg0.ibsrv.net/gimg/www.cor...9f5d5262b0.gif
It's front wheel drive. Cut the rails, fire it up, put in gear and drive it away from the carcass. . |
Some 40 years ago ... a local acquired a complete but well-worn kit car that looked like a cross between a Bradley GT and a Bricklin ...
... powered by MID-mounted drivetrain from fwd Eldorado's 500ci - TH425. Depending on angle, looked kinda cool ... was a real tire-roaster ... but handled like a turd in a typhoon ... loose as a goose ... ... Wasn't long before what was left turned up at local SADISCO wholesale auction. In USA, junk cars are routinely Donated to a Charity's pickup in exchange for a tax deduction. |
you admit you did nothing for 20 years to it. Why keep a useless engine for 20 more years that you will never do anything with? donate the car to a charity like Kidney Foundation.. get a tax deduction.. and THEY will move it. Besides Its too hot to work on junk . Better to sit by pool and drink beer now
(Post 1599500727)
https://cimg5.ibsrv.net/gimg/www.cor...52f1814579.png
(Post 1599500753)
(Post 1599500569)
Lars |
