From a dead stop! WTH
Well from a dead stop if I nail the go pedal it won’t spin or anything sort of dead on the bottom end until it gets around 2k+. It’s a 2010 corvette A6. I will also put it in manual and use the paddles and it doesn’t spin in second or anything when getting on it ??? Is it just so dumbed down from the factory and will do better once exhaust and intake is done and a dyno tune??
did you take it out of "traction control"? and once you do, do you know what to do when you get them spinning? or better yet when you take your foot of and the tires hook? careful what you wish for Mario, it will do much better after a good "tune"
Originally Posted by southofHoustonVette
(Post 1599519853)
When you floor it the PCM expects to see a rush of incoming air and with it, engine knock. In something of a "preemptive strike" to protect the motor from getting hurt it pulls a ton of timing out which is why it feels like such a slug. The car will actually launch noticeably harder if you don't completely floor it. The good news however is that it can be tuned out by a competent tuner. |
Also depends on your tire and temperature, as my PS4S tires won't spin in 2nd (or 1st if I roll in) with 550 whp. If you let your car idle for a long time and get your intake heat soaked, that'll also heavily rob power until the inrush of air can cool the intake down.
Originally Posted by jonjoy
(Post 1599521307)
l have an '06 Auto (that was tuned when it had aftermarket exhaust/headers with PO, now it is stock with NPP) that will break loose EASILY at launch, and if still on it, will chirp and break loose a bit shifting into second, and a nice chirp going into third....get a tune. While I don't do that often, it is fun (when conditions permit of course). That is without activating, or deactivating anything. Traction assist will display when it spins......Jon
never had that problem with 6 Speed...must be with autos only
:cool: |
Originally Posted by jbripps
(Post 1599525477)
(Post 1599525477)
Supercharge it.
Do a forum search on torque management. Very complex. And your C6 has torque management.
Originally Posted by Curt D
(Post 1599562262)
Wonder if they completely shut off your TQ management...which is not a good thing.
(Post 1599569820)
Who would have done that? And is there a fix for it ?
But...a tuner can alter the tq management. It's not good to shut it off. |
Understand sorry. Yeah my car just fee very slow and sort of a turd on the low or bottom end and unless you put it in the paddle shift mode and get the rpms to around 2.5 or 3k it feels like my wife’s Ford Flex
What gear ratio in the back? 2.56? Then just give it up....
Originally Posted by jim2527
(Post 1599570143)
Originally Posted by subfloor@centurytrans
(Post 1599521940)
It's working as designed believe it or not.
When you floor it the PCM expects to see a rush of incoming air and with it, engine knock. In something of a "preemptive strike" to protect the motor from getting hurt it pulls a ton of timing out which is why it feels like such a slug. The car will actually launch noticeably harder if you don't completely floor it. The good news however is that it can be tuned out by a competent tuner. Was this true of the C5 as well? I recall my C5 seeming fairly gutless when stomping it from a dead stop. Oddly, every now and then, it launched like its ass was on fire. |
(Post 1599570191)
Give what up. And whatever stock is
2.56rear X 4.03first = 10 which is decent. Any chance that in 'D' its shifting to 2nd gear real quick? |
get a tune should help alot
Originally Posted by damascus1986
(Post 1599571912)
