Compression test performed: take a look at my results
I finally got around to doing this and wanted to post my results. This was done dry and with an Actron Brand compression tester (part number CP7827). All plugs removed and foot to the floor on gas pedal while cranking. The engine had been run a few hours earlier and was still hot to the touch. I'm at sea level here in Jacksonville, Florida. Take a look, let me know what you think. Car has about 84,042 miles on it as of today:
#1 - 230 #3 - 220 #5 - 229 #7 - 230 #2 - 230 #4 - 229 #6 - 227 #8 - 237 So I should've done this a lot sooner because I've been expecting the worst for weeks now but this was good to see consistency across the cylinders. What I'm curious about are other owner's tests have shown median values around 180 - 200 psi for the cylinders, so I figured the Actron tester is "happy" compared to other brand testers used? Whatever the reason, I feared the worst because I've noticed that my oil dipstick pushes out about an inch or so and has to be pushed back in after some spirited driving. I've replaced the entire PCV system EXCEPT for the PCV valves. They still rattled when I shook them but I've made it an item to just replace them. A local Chevy dealer had one of them, the other was no longer available. So what do you guys think? #8 was either 237 - 235, it's a rough estimate because gauge in only in increments of five. Another reason I performed this test finally is because the car has become noticeably sluggish on acceleration. No trouble codes thrown but I need to replace the fuel filter anyway and while I'm at it I have decided to replace the fuel pumps in the tank. The third owner replaced the starter, coils, wires and fuel injectors before the fourth owner got the car sometime in 2017. At that point, the car was definitely stored outside and most likely not driven a lot because I found a mouse nest all around the starter, and the 4th owner just had no room in his garage to keep the car so outside it sat with a car cover. I got the car in August of 2018. The car is almost 30 years old and I believe a lot of its time since then was sitting in storage, so I wouldn't doubt one of the pumps has gone south. Last key thing: I don't think this is a variable in the test but some cylinders, the starter turned over the engine 4 times instead of 3. I don't think this skews the results but let me know otherwise. I figured, if there was a problem, an extra crank isn't going to jack up compression and give a false reading. Sorry for the paranoia! |
Looks good to me. Your at sea level so your reading will be higher. I’m at 5000ft so mine are lower around 200. Your good don’t over think it. I just did a buddies fuel filter, the car would barely get to 6k rpm without shuddering. After the filter it went straight to 7k and beyond. Also as the weather gets warmer you loose some of the performance due to heat saturation and the ecm cutting timing.
H :cheers: |
Those numbers are good.
Here's my most recent compression test: 1 - 213 3 - 213 5 - 220 7 - 220 2 - 235 4 - 215 6 - 215 8 - 215 |
Slightly high can be carbon. The readings are within 10% which is acceptable. Is there a particular condition?
Originally Posted by ghlkal
(Post 1599530389)
Originally Posted by Kevova
(Post 1599531610)
:flag:
Originally Posted by FASTAZU
(Post 1599552941)
1 - 228
3 - 230 5 - 226 7 - 230 2 - 225 4 - 228 6 - 225 8 - 230 |
Originally Posted by 1985 Corvette
(Post 1599553128)
Thanks, Steve. Looks like i'm in good company for decent results. Looks like the sky wasn't falling! (again)
:rock: |
