Had a new battery installed today so picked up a pack of 10a fuses. Plugged one in for the NPP and no change. Looks like vacuum/solenoid next on the list.
I have LT,no cats,mufflers gutted out, and those things stay OPEN! Lol I only close them when I go into my neighborhood.
Originally Posted by C5forGreg
(Post 1599623929)
Suck throught either one of the solenoid ports, and make sure that no air can pass through either ports without power to the unit. At start up the NPP controller powers up the unit to open the port and allow avacuum to pass through it from the intake manifold to suck the gates closed. Next start the car, or put 12v on the electrical connector and now the ports should open so you can suck air through them. :-) |
CI GS, When I 1st installed my Southern Car Parts M/W Switch the NPP was working
and the Switch was working...Within a couple of days the switch stopped working and the 10AMP fuse repeatedly would blow in the fuse adapter (plugged into bottom right corner) Paul from RPI/ Southern Car Parts) sent me another M/W device and its not making the NPP work either... 1) Why did installing the M/W switch cause my NPP System to fail 2) Do I just assume it the Solenoid 3) If I replace the solenoid will the M/W switch damage it ?? (Again) Chuck Auburn,WA |
Originally Posted by CamarosRus
(Post 1599668439)
08 Vette npp stays open intermittent
Sometimes the NPP works fine and sometimes it gets stuck open. I have the mild to wild remote and again sometimes I open the exhaust and close it with the remote went fine and other times it's sticks open and won't close until I shut the car off and come back later. Does this sound more like a vacuum line or the solenoid. I have no patience to start testing lines I'm wondering if it's most likely just a solenoid . And if it is the solenoid would it work intermittently like this thank you
Just a suggestion....I added NPP mufflers after I got my C6. It was not a stock NPP setup. While I purchased the NPP in a box with the vacuum line kit, I did not yet install it. I am not in a rush to do that since I like the sound so much. Is it possible that your previous owner did what I did? If that is the case, you won't see any "issues" discussed above. I think you can check to see if you even have vacuum lines?
Good luck! Jon |
