rear wheel camber?
When I put my 89 on hoist at home I noticed the right rear wheel sags down quite a bit further than the left. What would be the cause of this
Originally Posted by Rock Steven
(Post 1599535509)
does the spring look ok even arc? The camber means tilt of the wheel from vertical negative or positive, it will only affect the angle of the wheel tire. Not cause it ti=o hang noticably lower than the other wheel the sway bar will keep them even. |
The bushings on the larger bolts that attach spring to knuckle. Damaged or loose shock. Broken spring are also possibilities.
