Traction Control / Active Handling
2009
Traction Control / Active Handling need service. What do I need to check or do? |
Originally Posted by Tim Beilby
(Post 1599542947)
2009
Traction Control / Active Handling need service. What do I need to check or do? The service message is basically a voicemail reminder, with the codes being the voicemail. So to speak. Jiggling cables and unplugging the battery is like erasing the voicemail without listening to it first. |
(Post 1599542947)
2009
Traction Control / Active Handling need service. What do I need to check or do? If that isn’t the problem, check for other things being disconnected before you start throwing parts at it. |
weak or dead Tire pressure sensors will do it as well. check your tire pressure at the dash. if one is dead it will have "XX" instead of the pressure. Also if its just a weak sensor it may still read pressure but it wont show an increase in pressure as you drive and the tires get hot.
2009, if you havent changed them its time to. I hope its that simple for you. The other replies will certainly cause the same codes. |
Originally Posted by rabrooks
(Post 1599552993)
weak or dead Tire pressure sensors will do it as well. check your tire pressure at the dash. if one is dead it will have "XX" instead of the pressure. |
