Upper strut torque and bushings flatness (with pics)
So I torqued the nut on the upper part of the Bilstein struts to FSM spec (19 ft-lbs) and the bushings look like the pics below. Should I back the nut off until the bushings are more inline with the edges of the washers? They look really flat to me. I couldn't find anything in the included Bilstein instructions at all on this.
https://cimg3.ibsrv.net/gimg/www.cor...8f198e8bcd.jpg https://cimg4.ibsrv.net/gimg/www.cor...0312dd2ba1.jpg |
That is way overtightened. I don't have the torque spec handy, but are you sure it isn't 19 inch-pounds?
I just tightened mine down to a slight bulge, plenty tight.
Thanks guys, I loosened them up. That was the FSM spec 19 ft-lbs. I checked again.
Originally Posted by BuckeyeROC
(Post 1599549238)
This PDF from Gabriel shows great pictures on the proper installation procedure.
http://gabriel.com/wp-content/upload...stallation.pdf The bushings that came with the new Bilsteins that I bought for my 1996 are not the same as GM had used on the oem installation. GM is notorious for making bushings out of unobtanium. I installed the pin top shock bushings from Banski and kept my oem ones. |
BACK THAT BABY OFF. there isnt any cushion left with that
Cushion isn't the issue, the shock actually articulates a little and the bushings allow that, same issue as using poly bushings in the rear and having bind.
The pin top shock mounts from Banski are hard delrin. https://www.banskimotorsports.com/pi...ck-mounts.html They achieve their articulation due to the way the components are machined. Cushioning actually interferes with the shock working as the rubber compresses before the shock starts its work. |
That is way too tight and as you noticed, the SHOCK bushings are way too compressed. Back off until they are even with the upper washer. That is a nylock nut and will not back off.
