Problem with dad's truck
1995 Z71 350 auto 4WD - High miles (about 285k)
It stumbles and runs rough when cold. Settles down when warm. After a fair amount of "at temp" driving, it starts to sputter a bit. If you shut it off and immediately restart it, it smooths out. This is repeatable every time is starts to sputter. Turn it off and restart and it's fine for a bit. TPS has been replaced Disty has been replaced Wires have been replaced Plugs have been replaced Two different shops have had it and no one can figure it out. No codes. |
Fuel pressure checked at cold start and again when up to temp? It's TBI correct? Could be an injector problem....285K miles is a lot. Original O2 sensors as well?
285k? borrowed time with that engine, maybe it's time to get a newerish truck for dad
EGR valve?
Problem with Dad's truck is that Dad is too cheap to buy a newer one. Should be some reasonable deals on 2 -4 yo trucks. Stay away from any dealers near Lars, Gixxer, Wezzy, koko, etc.
Originally Posted by ratflinger
(Post 1599558812)
problem with dad's truck is that dad is too cheap to buy a newer one. Should be some reasonable deals on 2 -4 yo trucks. Stay away from any dealers near lars, gixxer, wezzy, koko, etc.
fly KSpaz out
Fuel filter?
Originally Posted by DJ_Critterus
(Post 1599558816)
bfm?
Originally Posted by beaversstonehaven
(Post 1599558832)
Fuel filter?
Sounds like it's not reading the correct air flow at different temps and turning the car on/off to reset everything fixes it temporarily until it sees the same conditions. |
Things that come to mind,
O2 sensor acting up , but not enough to trigger a CEL, Coil - weak, they act up when hot, run rough when cold as the spark is weak, There are a few other items, but you need to drive with a data logger to see which item is going out of / close to limits.. |
Originally Posted by Aerovette
(Post 1599558593)
It stumbles and runs rough when cold. Settles down when warm. After a fair amount of "at temp" driving, it starts to sputter a bit. If you shut it off and immediately restart it, it smooths out. This is repeatable every time is starts to sputter. Turn it off and restart and it's fine for a bit. TPS has been replaced Disty has been replaced Wires have been replaced Plugs have been replaced Two different shops have had it and no one can figure it out. No codes. O2 sensors lazy? |
(Post 1599558816)
bfm….FTW?
:D |
(Post 1599558593)
(Post 1599558593)
Originally Posted by KarlK
(Post 1599558826)
fly KSpaz out
Originally Posted by FourPennyDoug
(Post 1599558998)
mofo would have the whole engine torn apart by now :lol:
Try this.....
smack the egr valve and run a triple dose of lucas in the gas tank |
Originally Posted by BLUE1972
(Post 1599558873)
O2 sensor acting up , but not enough to trigger a CEL, Coil - weak, they act up when hot, run rough when cold as the spark is weak, There are a few other items, but you need to drive with a data logger to see which item is going out of / close to limits.. It behaves like a bad vacuum leak when cold...or too rich. None of that applies to the restart being immediately different. Also mentioned was MAF, but I'm 99.9% sure it doesn't have one. It's TBI. |
Originally Posted by TorchRedRocket
(Post 1599558971)
There's your problem. I'd say that truck has given him more than his money's worth. Time to move on.
(Post 1599559101)
They have another vehicle so it's not hurting them as far as getting around. My dad turns 80 :party: this year and he likes his truck so I want to help keep it running if I can.
