List of error Codes while things are working fine
Hello I'm new to corvette I bought my first one a couple of weeks ago.
I need some help with a list of error codes on the scan tool (the attached image) but note that everything is working fine (except the check engine light is on). What I already did: tested the evap solenoid next to the throttle body it's working fine and there is + voltage and the -signal from the ecu on the pins, the same for the evap valve next to the rear right tire also the AC, rpm and vehicle speed are all working fine, even when I fill up the car everything is normal(I read on the forum that the evap solenoids can cause some issue when filling the car). When I try to clear the codes with the engine off only the evap codes P0443 and P0449 show up when I turn the engine on or if I cleared the codes with the engine running the P0608, P0645, P0650, P0654 are there and after a while with the engine on the U0073 show up where should i start digging? please advice and can someone share with me the wiring diagram of the 2006? or any other technical document that can be useful for this issue thanks https://cimg9.ibsrv.net/gimg/www.cor...53aae5dc5.jpeg |
seems it's not a known issue, can someone share with me the c6 wiring diagram?
Originally Posted by Riachy
(Post 1599561183)
I need some help with a list of error codes on the scan tool (the attached image) but note that everything is working fine (except the check engine light is on). What I already did: tested the evap solenoid next to the throttle body it's working fine and there is + voltage and the -signal from the ecu on the pins, the same for the evap valve next to the rear right tire also the AC, rpm and vehicle speed are all working fine, even when I fill up the car everything is normal(I read on the forum that the evap solenoids can cause some issue when filling the car When I try to clear the codes with the engine off only the evap codes P0443 and P0449 show up when I turn the engine on or if I cleared the codes with the engine running the P0608, P0645, P0650, P0654 are there and after a while with the engine on the U0073 show up where should i start digging? please advice and can someone share with me the wiring diagram of the 2006? or any other technical document that can be useful for this issue thanks https://cimg9.ibsrv.net/gimg/www.cor...53aae5dc5.jpeg |
Forgot to mention that unless you have a bi directional scan tool there is no way you can test the control side of the vent and purge solenoids !!...you would need to use the scan tool to command and ground the control wires...both are ground side switched !!...with the volt meter back probing each side of the solenoid connector you should be reading 12 volts on the feed and control wires...if 12 volts on the feed and 0 on the control you have either an open in the coil (bad vent solenoid), short to ground on the control wire (wiring issue) or the computer driver for that control wire always stuck on (bad PCM) !!
