- C4 General Discussion
(https://www.corvetteforum.com/forums/c4-general-discussion-34/)
- - Odometer help
(https://www.corvetteforum.com/forums/c4-general-discussion/4284085-odometer-help.html)
joemactuba
06-11-2019 04:31 AM
Odometer help
I was wondering if someone could tell me if there is a way to see the real mileage on a craigslist 84 vette if he says the digidash is not working. When i look at replacements they have a odometer looking gauge at the top right. Is this a secondary mechanical odometer? Could i, in theory, ask him if i could remove the trim to see the actual mileage?
Joe C
06-11-2019 06:16 AM
Originally Posted by joemactuba
(Post 1599561204)
as far as I know, only one odometer on the (early) C4's. BTW, it's not a pure mechanical movement, but electro-mechanical. the whole thing centers around a small electric motor. there are ways to set back the indicated miles, but it requires replacement with another odometer movement, or disassembly of the original, and re-indexing the internals. unless big money's involved, not sure it's worth it for something on the lower end of the value scale. it is possible, however, that the odometer is working separately from the digital dash. depends on the internal circuitry, and power and grounds to the instrument panel itself. this is one area where you have to go on your "gut" feeling. -- :rock:
3D-Aircrew
06-11-2019 11:43 AM
My atari dash went out on my 86 and when it was out the odometer still worked. If you drive it make sure it still is working.
PS: the trim has a window cutout for the odometer.
383vett
06-11-2019 01:36 PM
As mentioned, the odometer on early C4s are not digital and operate even if the dash is out. The seller should be able to provide you with a picture of the dash and odometer.
