mystery bolt
OK, the odd question of the evening. Anyone know what this bolt goes to? It's apparently been in my ash tray for at least 15 years which is the last time I drove the car regularly. Given the tapered end I'm guessing it hits a blind hole somewhere. And know, I don't think it's related to the knocking sound I've been trying to diagnose on another thread.
https://cimg8.ibsrv.net/gimg/www.cor...3162d353d0.jpg https://cimg1.ibsrv.net/gimg/www.cor...ab145a5c8e.jpg |
Flux capacitor mount bolt.
Mystery bolt
This might be the bolt that goes behind the parking brake bezel. It attaches in the middle compartment behind the parking brake.
Originally Posted by jim2527
(Post 1599566184)
Originally Posted by Kaper220
(Post 1599566271)
Those are used throughout the car. Check hood hinges, hood prop, hood latches, radiator upper mounts, fender splash shields (2 are by side molding). Pretty much all over.
Originally Posted by SH-60B
(Post 1599574949)
The bolt behind the center console is only on early Vettes, not 80s.
That looks like one of the 8 seat bolts, or the battery hold-down bolt.off chance of the steering wheel bolt (one of two) but I think those are bigger. |
i had a knocking noise when i stepped on or let off the gas coming from the dash. turned out to be a bolt in the ashtray!
(Post 1599580783)
There was a time I had to replace my oil pressure sending unit in an '87 Olds Delta 88. The best tool I found to get the old one out was a pipe wrench. After replacing the sender I started the car and everything was working fine. That was on a Sunday. Monday morning I hopped in to go work. Back out of the drive and headed out. But at the first right turn I a clunk, clunk, clunk. Straight was fine. But then the same thing on the next right. I was only a couple blocks from the house, so I went back. As I didn't have time to work the problem I hopped in the vette and took it to work. When I got home that evening I crawled under the car and saw some rusty rectangular rod handing loose. I couldn't imagine what part of the steering linkage it was. So grabbed it and pulled it loose. I'm sure you guessed it - my pipe wrench which I had apparently just shoved up out of the way while I was reconnecting the sender. |
Originally Posted by Bikespace
(Post 1599577360)
Originally Posted by vince vette 2
(Post 1599581718)
Shouldn't be seat or steering wheel as I haven't touched them. I think it's too small for the batter holder, though I admit that did wander off. It's currently replaced by a toilet pedestal hold down bolt which was the first thing I found that fit. The freedom of having a vette which is not destined to become a classic - if you have it, it fits, it functions, and no one will see it, use it.
(Post 1599584411)
I'm sure if you were missing a seat bolt, Kaluah would have mentioned it.
Meanwhile, I haven't looked too hard to find a place for the screw yet. Instead, I got the car past inspection on Saturday. It was only 6 months out while I was getting everything back into it. It's fun going into a garage where there's a good chance most if not all of the mechanics are younger than the car and haven't ever seen a car with a carburetor. Had them do an alignment check. 1 camber and both toes were out of spec, the camber too negative and the toes both negative. Hey, getting 1 of 4 in spec I thought was pretty good. So I'm working on getting the other three back in spec. |
