PDR GPS track mapping
Would anyone know why my GPS track mapping would not be working? I've only been to two track days so far, so am not sure if I am doing something wrong, because it does not show and from what I understand it should come on automatically. Also, while mentioning this...I see some PDR videos with the track mode setting just above the rpms and others do not. Was this just a change they did later on? Mine doesn't have that either.
You pick the layout you want before you start recording in terms of what data you want as part of the video...
Then you start recording... Then on the track you tap "mark finish line" - and thats' where it will count your lap times based off of and trace the track route via GPS. If you are at a multi-day event at a single track - you only need mark the finish line once... but every time you change tracks you need to mark it at the new track. |
Originally Posted by fishpick
(Post 1599569885)
