Is anyone using the "OBD2 Fusion" app ?
hey guys,
is anyone using this app? I downloaded it- hoping i would be able to see my alcohol fuel percentage and air fuel ratio- but i'm not getting anything. I am able to get rpms, engine load etc etc, but all i really need is air fuel and alcohol content. any help would be appreciated. |
Originally Posted by howdigethere
(Post 1599569543)
hey guys,
is anyone using this app? I downloaded it- hoping i would be able to see my alcohol fuel percentage and air fuel ratio- but i'm not getting anything. I am able to get rpms, engine load etc etc, but all i really need is air fuel and alcohol content. any help would be appreciated. EDIT: looks like you might be using an iPhone, I've heard the app called "Car Scanner ELM OBD2" is comparable to the Torque app for Android. |
iphone :(
(Post 1599569848)
iphone :(
Does it give alcohol fuel content and afr?
Jay, just finished watching your video. can you confirm that the ethanol feature actually works please?
thanks |
(Post 1599570601)
Jay can you confirm that torque pro can give alcohol content and afr? does it work on yours?
hmmm
ive got the sensor installed, and i've been using an aeroforce digital obd2 gauge to get the readout- but it would be much more convient to be able to read it through the app. i wonder if the fact that im using a carista obd2 module makes a difference... ? |
(Post 1599570651)
hmmm
ok cool. thanks for the response.
im troubleshooting some stuff with obd fusion. if it doesnt work im gonna download torque pro on an older android phone i have and just keep it in the car for when i need it. thanks again |
(Post 1599570788)
yes yes yes!!!
got it to work- i created a custom PID from the torque app onto fusion, and its working. this is so cool! https://cimg1.ibsrv.net/gimg/www.cor...48cc39f14.jpeg |
I thought I saw on one of the app reviews that there is some OBD apps that allow info to show on HUD in our cars. Anyone know & a name of app or the plug in that transmits to HUD or DIC? Thanks! Yes, I googled w/o luck.
Originally Posted by madrob2020
(Post 1599575973)
There's a few out there that will ACT as a hud, but there are none that will use our factory hud. |
(Post 1599575731)
yes yes yes!!!
got it to work- i created a custom PID from the torque app onto fusion, and its working. this is so cool! |
Jay- are you able to get actual AFR or just commanded AFR on torque?
(Post 1599576778)
C7Zs do not have wide band O2 sensors from the factory so.....unless you added one, you won't see AFR.
Originally Posted by ajrothm
(Post 1599577126)
(Post 1599575731)
yes yes yes!!!
