C5 suspension upgrade
I have a stock 2002 c5 I'm planning to improve my handling , my current plan is to get better shocks, end links, sway bars and bushings looking for recommendations
C6 Z06 shocks, C6 Z51 sway bars, Moog end links.
https://www.corvetteforum.com/forums...rformance.html |
I recommend you do a search on this very topic. It's been discussed a gob-zob-lazillion times. You will find that the C6Z OEM parts are a very cost effective upgrade along with lowering.
Originally Posted by knewblewkorvette
(Post 1599571657)
Originally Posted by Sydwayz
(Post 1599571676)
Originally Posted by StreetLS02
(Post 1599572031)
Thanks for the Info , I have the electronic suspension do you know where I can get the shock stimulator/resistor ?
No problems with codes or speed limiters. |
C6Z shocks is what I went with and has been a fantastic upgrade. I also went with the Johnny O'Connell front and rear sway bars with metal endlinks that came with it. Car handles on rails now.
Originally Posted by Not4spd
(Post 1599572508)
Originally Posted by CQRT
(Post 1599572089)
I put Z06 shocks on the car since the electronic adjustables were so expensive . . . .the shop then went into the ECU and programmed out the F55 feature and taped off the connections.
Do you currently have the F45?
C6 Z06 shocks, C5 Z06 sways, Moog endlinks, stainless brake lines while you're under there.
C6Z shocks, sways, and metal end links is the most cost effective best upgrade. Roughly $300.
I'll be having a full set of Moog end links for sale with like 10 miles on them lol if you're interested. Great end links for sure but turns out I need something adjustable. PM me if you're interested.
(Post 1599572980)
I've heard good things about those I'd like to get a pair eventually but it's a little more that I wanna spend on a set of sway bars currently Haha
(Post 1599571657)
(Post 1599571657)
Originally Posted by 4XLR8N
(Post 1599575780)
:iagree:
I put on Steinjager front and rear sway bars with the HD end links a couple of years ago. The are the same size as C6 Z06 bars:
https://www.ebay.com/itm/Steinjager-...UAAOSwSL5cdbHw The price has gone up considerably since I got mine--I think I only paid like $230 delivered. They made a nice improvement over my base (soft) suspension. Keep in mind what tires you have will make a difference too. I went to non-run flat tires this year and the car drives so much better! |
C6 Z shocks and sway bars will make a nice difference in how your car handles and the price is very reasonable.
Originally Posted by v6turbo87
(Post 1599582490)
Suspension ordered
I ended up getting c6z shocks and z51 sways with moog endlinks and poly bushings thanks for all the info guys , cant wait to get em on the car 🤙
