Teaser shot of our C7 trunk tank with a twist
Many people have told us they would love to run a trunk ice tank but losing the targa top storage function isn't something they wanted to give up. So we decided to come out with a solution that does a few key things.
1) Ability to hold lots of fluid for A2W Centri setups or PD Blower packages 2) out of the way in the engine bay 3) large 6'' opening to making dumping ice in a breeze 4) internal Rule 3700 pump to assist the front pump in flowing water extremely fast through the system 5) minimum loss of storage, targa and cargo net still fit, also can access fuses under carpet still for service later on 6) uses OEM mount locations under carpet for a secure install 7) Pump sits in well pocket so when you drain you cannot accidentally drain to much and run pump dry 8) Weight over the rear where you want it most if you have to add weight to a car 9) Exceptional fitment like every CPR product 10) Available with lines or without 11) Available Raw or powder coated textured black (coated is standard, deduct $25 for raw) Pricing will be $1300 for complete system with lines and fittings to get it to engine bay and back. You will have to make up front connections based on your setup. We can change fitting location just plan on additional lead time as the way we run it will be what we stock. $1080 will be without lines/fitting. It will have female ORB on the tank to set it up how you wish at that point. https://cimg1.ibsrv.net/gimg/www.cor...a2f57efaa2.jpg https://cimg4.ibsrv.net/gimg/www.cor...afed4b1120.jpg |
tank
Originally Posted by Joe@CPR
(Post 1599571551)
