Sniper EFI gas tank filler neck issue in 75
Afternoon,
My mechanic, who is currently installing a 383 and 5-speed in my 75 texted me this afternoon about the Tanksinc gas tank. I purchased the 1968-74 tank off the Holley website to go along with the Sniper EFI system. My understanding was that the tank would work...but that the straps would be an issue. For those that swapped to an Tankinc EFI into a 1975 or later.....what filler neck did y'all use? Thanks. |
Most people use the 82 Vette tank.
Originally Posted by Gunfighter13
(Post 1599573234)
TO O.P. What kind of problems are you having fitting this tank into your 75? Providing a description (or pictures!) of the problem will get you much more response. |
Originally Posted by jano344
(Post 1599571973)
Afternoon,
Originally Posted by scottjamison
(Post 1599576387)
This is the tank I used. It fit perfectly. https://www.holley.com/products/fuel...s/parts/19-148
Originally Posted by RBrid
(Post 1599576741)
Yeah, but I think you have a '68. What kind of filler neck does one use for a '75-'77 vette with that tank? Thanks.
https://www.ecklerscorvette.com/corv...Product_Upsell |
Originally Posted by caskiguy
(Post 1599576912)
Just a guess but this shows the filler neck connected to the sending unit. So I'm guessing one would have to go with a exterior pump and drill a 3/8" return to the tank ? Although it is said 5/16" can work for the return. If I'm way off base here please educate me.:flag:
https://www.ecklerscorvette.com/corv...Product_Upsell Is that tank's opening compatible with a '75 - '77 vette? I should have asked J.Abbott that question in this thread: https://www.corvetteforum.com/forums...post1598666030 |
(Post 1599577043)
Yo caskiguy, by filler neck I mean the part in which you shove in the gas station nozzle :)
(Post 1599571973)
Afternoon,
Thanks
