-   C7 Z06 Discussion (https://www.corvetteforum.com/forums/c7-z06-discussion-170/)
-   -   Tire change messed up drop spindles lower!! NEED HELP! (https://www.corvetteforum.com/forums/c7-z06-discussion/4284727-tire-change-messed-up-drop-spindles-lower-need-help.html)
Shawn_Randhawa 06-12-2019 09:31 PM
I have the z07 package and drop spindles on it, it is lowered a good amount but when I took it to get the tires changed, I got it back and instantly when I got home to take a deeper look, it looked like it is back at stock height? I called and they said it’s just with the new tires, which makes it look higher. It is very clear that the front is higher than before but they said it’s with the tires. True or false?
MCK_Z06 06-12-2019 09:37 PM
They always sit higher than what you have it set to when you have had the wheels off the ground and then put it back down.
I have drop spindles as well and the same happens when its been on a lift or has been jacked up on each corner.
Drive around for a few days and the suspension should settle back down to where it was before.
BTW: This seems more pronounced on Z07 equipped cars I have noticed. (like mine)
Shawn_Randhawa 06-12-2019 09:42 PM
Thanks so much! Had me worried for awhile lol 😂
BrunoTheMellow 06-12-2019 10:42 PM
Z07 springs are stiff. Let it settle.
Shawn_Randhawa 06-12-2019 10:45 PM
Ok sounds good! Thanks
