Dome top pistons L48
Hey all,
For years my father had the 350 4 bolt sitting in his garage. Now it has found its way to mine. 😂 Anyway, after researching the casting #'s on the block, heads and intake. They all match up to be an L48 with a block cast date of Aug, 14 1973. I've been reading about the low compression with the 993 heads. And the mods some people have done. So I was thinking of polishing the runners and chambers. And maybe increasing the valve size with dome pistons. Not trying to go crazy. I know I'm limited on the runner flow. But what do you think? Thanks for any input! |
Any particular reason why you are stuck on old iron heads? What cam, compression are you thinking of? Build plans/budget?
Fwiw there are some nice aftermarket irons...and tfs double hump aluminums |
