Throttle body question.
I had the "pleasure" to help a friend with his 2010 (3000 miles, automatic trans) . The cars died and was towed home. Had an error code for throttle position sensor. When he pulled the plastic air intake from the throttle body he found a piece of cardboard (see pics) stuck in the butterfly of the throttle body. I've since got the car running but was wondering what this is. Is it something from the car itself or did it somehow get stuck in there. Can't find the part from the number on. The cardboard has a sticky side and what looks like precise folds. Anyone know what t is and what, if any purpose it serves? Thanks:confused:
https://cimg6.ibsrv.net/gimg/www.cor...d8482b0aeb.jpg https://cimg7.ibsrv.net/gimg/www.cor...ea0dbd8181.jpg |
https://arb.parts/Executive-Order/D-215-80
Courtesy of your CA and NY State government requirements. |
Originally Posted by HOXXOH
(Post 1599597552)
Thanks to both for the info. Much appreciated.
I was thinking of removing mine inside the intake. Some of it is coming unglued. What did you use to get it all off? I'm guessing it's a pita to get rid of all of it?
Originally Posted by Beef97
(Post 1599607505)
Originally Posted by Mikey Hawks
(Post 1599608830)
This one came off all by itself and lodged in the butterfly of the throttle body.
(Post 1599607505)
WD40 will remove the glue.
WD-40 may help remove the glue. It does work well on old masking tape glue, but is ineffective on packaging tape glue.
