Throttle Body return spring replacement
So, my throttle return spring is busted. I can manually move it, but it will not return by itself. I have been looking for a replacement spring or whole throttle body, but cant seem to find anything for the LT5. Does anyone know where I can find a replacement for with the spring or the whole thing? Thank you, in advance.
Did you try Jerry's Gasket's? Jerry usually has small parts like that in stock or may have a whole throttle body.
https://www.jerrysgaskets.com/ Rich |
Originally Posted by Scrrem
(Post 1599608608)
https://www.jerrysgaskets.com/ Rich :cheers: |
Originally Posted by ccmano
(Post 1599609697)
Good suggestion, call Jerrys if you don’t see it on the site. He sometimes has things like this that are not listed. Also call Mark Haibeck, www.zr1specialist.com, he may have it in the shop. Strange, I don’t know that I’ve ever seen one of these break.
:cheers: |
(Post 1599609697)
:cheers: |
Originally Posted by 90VetteZR-1
(Post 1599610562)
Also, thank you so much for reminding me of Jerry's, I knew there was a site I just couldn't recall. They do have a TB, but I didn't see a spring. I'll call, but even if they dont, at least I found a TB. Thank you, both, very much.
Good luck and thank you for your service! H :cheers: |
(Post 1599612409)
Do yourself a favor and call Marc Haibeck about this before you start down this road. He’s very easy to talk to and will give you a straight opinion about what’s going on with your car. As I said I’ve never heard of the spring going bad. I have heard of the throttle plates binding due to worn out throttle shaft bushings. I suspect that’s what you may be looking at. Marc can rebuild the throttle body to better than new.
(Post 1599613132)
I'll shoot him an email today. Thank you for your support.
Best of luck H :cheers: |
Its called a Torsion spring, might try kinsler fuel injection...
