2013 C6 Vette and music via bluetooth audio?
i have a galaxy android phone and a 2013 c6 vette. How do i play my music on my phone via bluetooth? ps 1.the phone is paired but only phone calls work via bluettoth
2. get a "Device Not Detected" error msg if i attempt to use aux cable via console. HELP... please. |
Unfortunately the bluetooth in a C6 is only for phone calls and will not stream music. Some have purchased a small bluetooth adapter that plugs into your aux cable jack to stream music wirelessly from your phone. I ended up replacing the head unit with a Pioneer so I never used one but members claim it works well.
Thank you touchredfred!! where do i purchse these bluetooth adaptors for my car? What exactly are they called, just a "bluetooth adaptor"?
You can find them on Amazon or even at a Walmart. I think the cost is usually between $15-25 for one. I did a search for "bluetooth aux adapter for car" on Amazon and a few come up. Not sure which brand is best or if it matters. They plug into the auxiliary jack and you have to charge them every so often since they run on an eternal battery.
Originally Posted by torchredfred
(Post 1599642950)
you can find them on amazon or even at a walmart. I think the cost is usually between $15-25 for one. I did a search for "bluetooth aux adapter for car" on amazon and a few come up. Not sure which brand is best or if it matters. They plug into the auxiliary jack and you have to charge them every so often since they run on an eternal battery.
