Just Freshened RPM Level VII(+) 4L60E/4L65E w/Brake Built C6Z06 differential & more!
SOLD!
*Lowered Price!* Just Freshened RPM Level VII(+) 4L60E/4L65E w/Brake, Triple Disk Lockup Converter, Built C6Z06 differential & more! Would rather sell complete without separating. Includes: RPM Level VII(+) 4L60E/4L65E *Media blast transmission case *RPM Level V 3-4 clutch pack *RPM reinforced sunshell with collar and bearing *Heavy Duty double caged 29 element sprag *4L65E low roller clutch *Billet 4th gear servo *Transgo HD-2 shift kit *Corvette Servo *Wide 2-4 band *Updated aluminum accumulator piston *Bushing kit *New shift solenoids *New GM valve body spacer plate *Seal & gasket kit *GM Filter *RPM Spec clutch and band clearances *RPM sleeved input drum *Billet over-run piston *GM 5 pinion planetary gearsets - front and rear *NEW Extra WIDE Heavy Duty double caged 29 element sprag *300m Billet output shaft *4L65/70E low roller clutch *Billet 2nd gear servo *300M Billet Input shaft *Billet Pump Rotor *Billet Forward Piston *2-3 HD Apply Valve *Deep Aluminum pan *Micropolished Internal Parts PLUS: Trans Brake Smart tech input drum Extreme Duty Prop shaft, 3.5 inch Custom RPM Converter - Triple Disk with Lockup ZR1 Torque Tube RPM C6Z06 Stage 4 Differential*Media blast case *New seals *300M left shaft *300M 2-piece right shaft *C6 Z06 pinion support *Wavetrac differential ZR1 Torque Tube $10k new, $6900! (was asking $7900 + shipping or best offer (PayPal accepted, add 3%) |
PM sent
Wednesday BUMP!
humm I'd just need a C6 cradle for this to fit into my C5 right?
Originally Posted by ultradriver10000
(Post 1599715470)
What power level is this good for? Specs on the converter? Spec'd for N/A, nitrous, supercharger, turbo??
Originally Posted by jayyyw
(Post 1599719586)
Converter is a triple disk with lockup..stalled around 3200-3400 for my previous 427 TT with TTi X kit |
Very tempting. I'm sure a lighter weight vehicle can help it survive longer as well.
(Post 1599722321)
My C5 is/was a bit on the heavy side as well. It's still a full street car with working AC, power everything, etc.. It's even heavier now with the cage :ack: |
will this tranny fit on a 2002 Fbody WS6 Trans Am to be exact or is it Vette specific?
Originally Posted by Omega Doom
(Post 1599741765)
Wednesday BUMP!
What gear ratio is in it?
3.42's
Monday BUMP!
Sunday BUMP!
Lowered price to $6900! This needs to go! :)
Would this fit in a c6z without any modifications?
Originally Posted by droptopsnake01
(Post 1599950749)
Diff SOLD! Creating new post for other available items
