Shipping C1 Powerglide
I will be shipping my cast iron C1 powerglide across the country and I thought I read somewhere there is a way to lock the torque converter in place for shipping. Anyone has any experience or suggestions on this?
Many thanks |
Can't you just bolt a bar across the bell housing to keep the torque converter from falling out?
Bolt a strap across the tranny mounting flange.
For shipping, get a cheap plastic cooler from Walmart (not a styrofoam one!), wrap the tranny in bubble wrap and slide it in for a tight fit. Then wrap the lid to the body of the cooler with strapping tape. I’ve done this many times. No need to build a crate or fool with other shipping containers. |
Drain it first, and rely good! "This side up' doesn't work!
You don't want it to end up in the "package leaks" pile. |
I recently shipped a 1957 powerglide from California to Alabama. I built a pallet, if I recall correctly, which was 24" x 32" and used plumbers tape to strap it down with construction screws. Worked just fine. Whatever you do, make sure it can be moved with a forklift. The weight of mine with the pallet was approximately 250 lbs.
https://cimg4.ibsrv.net/gimg/www.cor...17d5d20e20.jpg
This is all you need to hold the T.C. in place, just a think flat bar with a bend in it. |
I haven't shipped anything big recently (shipped a turbo 350 a few years back) but I believe the major shippers have a 150 lb. max. Most of them have freight for heavier/larger items. Don't rule out Greyhound too if departure and arrival sites are reasonably close. If a cast iron PG is close to 150, shipping the TC separately could be considered.
C Ya, Joseph Rock Frankenstein 59 |
I shipped an aluminum powerglide (62') without the torque converter via Greyhound strapped to a cutdown plywood pallet four years ago. Shipped from LA to Dallas with no problems and less than a week transit time. Worked out great and was much easier and cheaper than a freight line shipment.
Claude |
