Eforce removal 06 Z question
Has anyone removed the eforce supercharger from their LS7 in order to find a faulty lifter etc.?
Im wondering if I can leave the injectors in and what else. Id like to do as little as possible to remove/replace. Any tips? thanksū%x |
Coolant lines, belt obviously, fuel rails/injectors, and vac lines need to come off of it. Then just pull the heads as you normally would.
I think you will need to remove the fuel rails and injectors to get to the bolts that hold the supercharger to the heads. As CHR89 states, some of the coolant lines, belts, wires, etc. to be able to pull the heads.
Originally Posted by Spaceme1117
(Post 1599687853)
What I meant was if there were any shortcuts or to look out for. I'm surprised to see 2 fuel lines on on each of my fuel rails. Now this thing is friggin heavy! I got it to move off of the heads and forward a bit. I found everything I could. The rearmost bolt on passenger side comes off easier if one removes the MAP sensor (I think that's what it is) I still have to see if there is something else holding this thing on or snagging or if I'm just a weakling. I got a look at that cnc'd LS7 intake port...thing of beauty. Thanks guys. |
