Need buying advise before buying a 96 coupe
Any advice or questions to ask before buying one of the 2 1996 coupes I’m looking at.
Thanks in advance! Scott |
Condition and maintenance history are very important on these because cost to bring a tired example up to an acceptable level will quickly exceed a great example. The cost just to repaint a C4 at a reputable body shop will by itself almost exceed the cost of the entire car.
Originally Posted by scott.johnson57
(Post 1599687140)
Sure. I’m looking at a 93 white coupe with red Int. 27k miles. &13,900
(Post 1599694833)
At 13k , unless a ZR1, the car should not have obvious flaws and minimal wear. You will also want in pre purchase inspection. You should be flipping the bill for that. Since you want the inspector looking after your interests not sellers.
Good idea!
Need an inspection done in Columbus Ohio. Who should I call. Thx guys!
(Post 1599694833)
I really like the white or silver cars with red interiors but just keep in mind that the average C5 has been dropping in price which puts downward pressure on the C4. I would highly recommend giving yourself at least 3-6 months to look and drive before you pull the trigger. One example of why I am happy I waited and made sure I was getting the right fit was because I found the sport seats in the '95 were so much easier to get in and out of for my 6' 4" body. I would have ended getting a C5 had I not found out about the available sport seats on the '94 - '96 models so it really pays to give yourself a time period to really check them out. You might find that the C5 is a better fit for you but will not know if you have not compared. A really nice vette in person can put the best of us in a trance so very important you give yourself a time period to look at many examples in person. If one sells while your are doing this there will be another one to come along. |
purchase a copy of the corvette black book, that will answer questions you did not know to ask.
Buy a new one and keep it for ever!
look under the battery tray for signs of corrosion. Inspect carpet area, especially on passenger side footwell for signs of past water damage, usually from clogged A/C plenum drains backing up water. It is very common for the not very thick plastic on the console and console lid to be cracked; replacements are available. On a lift check the underside of the floorboards for signs of impact, not uncommon on a C4. Ditto on the oil pan. Is the steering wheel / tilt mechanism tight? Weather stripping is always an issue. Door sagging on hinges, especially drivers door? Is the spare tire and carrier still on the car? Headliners tend to sag. Is the wrench that bolts and unbolts the top still with the car? Are the drains around the gas cap well clear and free of debris? I can go on, but I don't want to discourage you. You can get a hell of a car for the price of an used Toyota.
Thanks everyone!
I bought a 93 Coupe with only 27K miles. White ext and red int. Mint condition. Can't wait to get it!!! |
Don't forget to post pictures when you get it. Good luck with the new car.
(Post 1599722178)
Thanks everyone!
I paid $13,500. The appraiser said is was one of the nicest ones he’s ever seen.
Congrats on your new '93 Vette and welcome to the Forum.
Thx guys
:worthlessnopics:
