Cylinder Head Advice
I've been looking at Trick Flow 255 and AFR 260 heads. I've done searches on here and at ls1 tech and havn't found too many people discussing these heads. Does anybody have any experience with these heads that could make a recommendation or of another head that would be a great fit for what I'm doing with my supercharged 427. Max budget is 3k for heads complete.
1967 camaro pro-touring 5.3 texas speed block with darton sleeves (4.130 bore with 4.0 stroke) Wiseco -20 pistons (around 9.6:1 compression) BTR stage 3 pds cam LS9 supercharger Johnson lifters Yella Terra 1.7 rockers 4l80e trans (2800 stall) 12 bolt (3.73 gears) Thanks guys! |
Why not the PRC heads from texas speed? You already running their shortblock.
I have the PRC's on my ls7. |
So... you're building a 427" LS3? The heads you spec'd are not for a LS7 so you'd probably find more info on the C6 tech/performance forum.
:confused:
Correct, I’m supercharging my 427 with the ls9 supercharger. I dropped a valve with ls7 heads and after the research, I’m done with ls7 heads. I want a head that is more reliable and I’m going to be making over 800 horsepower anyways so I’m fine. My 67 weighs around 3,000 lbs so I’ll be flying at that power level. I want ls3 style so the supercharger bolts up without adaptors. I posted here because I wasn’t sure if any of the ZR1 guys have played around with these heads since they flow more than the ls9’s. I will be around 12 lbs of boost.
Originally Posted by fred50stang
(Post 1599699432)
Another question I have is at what boost level should I go to arp studs for the head bolts instead of arp bolts which is what I was running?
I'm running Trickflow 255s on my TT GTO, its a 403ci Gen 4 forged iron block (9.8:1). They're great cylinder heads but be advised the valves in them from Trickflow are junk. They are the lowest grade Ferrea valves and will "tulip" under extreme heat and cylinder pressure. I upgraded my intake valves to the BTR Victory titanium valves and Manley inconel exhaust valves. I was able to run the original Ferrea's for a while but they didn't last long at 1000+whp. I'm at 1150+whp now and the Victory/Manley valves have been solid for a year now, probably 150+ full passes and 5k miles of street use.
I plan to swap to a cathedral port TFS 245 on the GTO and run the 255s on my ZR1 in the future. |
Originally Posted by 6point0 goat
(Post 1599701354)
For about $50.00 you can ship your original heads here....https://www.latemodelengines.com/index.php/ I had mine done there and they're perfect. They will custom build them for your exact project.
Originally Posted by meanjoe
(Post 1599703055)
Fixed heads arent the issue the parts used are
PRC 260’s. Record ZR1 runs them.
Peoples Republic of China?
Originally Posted by Innovate
(Post 1599705249)
LS7 heads are fine if you replace all 16 valves in addition to the head work. It’s stock valves/coating + geometry + exasperated by 1.8rr, and 07/08 rockers if you have those. If you start with an LS7 casting and build with quality parts and good machining there is no issue.
Ls7 heads aren’t an option at this point. I already have a ls9 supercharger and I don’t want to use adaptors.
Originally Posted by piratebaseball
(Post 1599706012)
According to their website, those are six bolt heads. I'm only going to be using 4 bolt.
(Post 1599708568)
ls7 heads aren’t an option at this point. I already have a ls9 supercharger and i don’t want to use adaptors.
Originally Posted by Millenium Z06
(Post 1599708576)
mast ls3
