Changing battery
Is this an easy do it yourself job or not?
Checked youtube but no luck. |
Well, how mechanically minded are you?
Getting to the battery is not a big challenge. Getting the battery disconnected and removed requires some dexterity. Care must be taken to not tear the carpet. Care must be taken to get it wired back in exactly as it was when you took it out. The wires and connections must be aligned as they were to insure a good electric connection. I'm 75 and I can do it. Cheat sheet: http://netwelding.com/Battery_Issues.pdf Props to JerryU Elmer |
Timely post, need to replace our battery tomorrow, thanks!
If in doubt about getting everything back as original, take a picture(s) of the way everything is before and as removing the old one. :yesnod:
Excellent advice. This works superbly to help remember where everything went whenever working on a car, etc.
I did mine 2 weekends ago, google C7 battery and I took a screen shot. Easy beasy the only issues is lifting it up and angling out.
Jerry's writeup is very good. An easy DIY.
I am 75 also and did mine but NEVER again... the $25 dealer wanted to swap them was a bargain! Good luck, CJ
I'm nervous about scuffing, ripping, and hurting my baby.
I'd be more nervous about the dealer scuffing, ripping and hurting your baby LOL. |
Good point.
Found this! Posted a couple of weeks ago. The part I was concerned with is a complete module versus disconnecting every point. |
Originally Posted by CourtneyJudd
(Post 1599712301)
Originally Posted by DCortez
(Post 1599722588)
Originally Posted by Maxpowers
(Post 1599723378)
I'd be more nervous about the dealer scuffing, ripping and hurting your baby LOL. I'm 76, it's NOT that hard. I bought a "cheap" lifter that fits over the posts BUT they are on one side and as I was lifting it out of the small hole, it slipped! I just put the battery on the rear area and lifted it out with my hands! Agree lifting it over the spoiler or fender is risky unless you buy the more expanse "Ice Tong" tool someone mentioned. For those that think the seller will do it free, when I brought the old battery back to get my $10 deposit fee told the manager to be careful, about ripping the carpet and how to get the power board off! I replaced mine early in 2016. He said, "We no longer change batteries in cars where it's not easy to get to." I understand that as I was planning to change the wife's ~4 year old battery in her Porsche Cayenne. Found out I needed a special very large Torx wrench because I had to remove the drivers seat! Not just tilt it, remove it! Lots of plastic trim on the bottom and many wires. Was bringing to get washed and the fellow said nice car too bad it cost $900 to change the battery! I said how did you know? He said another fellow brings his in and that's what he paid! :lol: Instead, traded it in on a new BMW 5X SUV! She liked I better! |
DCortez;
Great question: Thank you, for the informative video too. Prerequisites for new battery installation: 1. Clean all electrical connections ? 2. Application of dielectric grease ? 3. Reinstall battery drain hose? Please, remove all your Jewelry, watch, and your metal belt buckle, anytime you are working on a vehicle that you value? Many thanks, Ray "Save Harley Earl's front engine Corvette". |
Originally Posted by Rayland
(Post 1599767541)
DCortez;
Great question: Thank you, for the informative video too. Prerequisites for new battery installation: 1. Clean all electrical connections ? 2. Application of dielectric grease ? 3. Reinstall battery drain hose? Please, remove all your Jewelry, watch, and your metal belt buckle, anytime you are working on a vehicle that you value? Many thanks, Ray "Save Harley Earl's front engine Corvette". Yes, don't forget to reattach the vent/drain tube on the outward side of the battery. |
Battery change
Great video, best I have seen on it
(Post 1599712301)
Excellent video!
Thanks |
I have been using a Deltran Battery Tender for over 30 years and have had Delco batteries last for almost 10 years when connect to my 1989 C4. My 2016 C7 is connect to a Deltran Tender now and i hope to get more than 5 years !!!! I now have a Deltran Wi-Fi battery monitor and can check my battery status on my phone !!!
https://cimg7.ibsrv.net/gimg/www.cor...3bc254a112.png |
Finally got around (work travel ended) to changing it out.
Would add disconnect drain tube and "plastic 90" by negative terminal before you start and don't reconnect until new battery is seated. |
