Does my clutch fork look broken?
To you guys? Or damaged in anyway? I unbolted the slave, and put a borescope in there as best as I could.
Brandon Oh, car is a 96 lt4 https://cimg4.ibsrv.net/gimg/www.cor...e76aa2f245.jpg https://cimg5.ibsrv.net/gimg/www.cor...daa2e04548.jpg https://cimg6.ibsrv.net/gimg/www.cor...f6afbedaa8.jpg https://cimg7.ibsrv.net/gimg/www.cor...85fc8b0418.jpg https://cimg8.ibsrv.net/gimg/www.cor...338d2da31d.jpg |
Help? If it's dumb question, sorry. I'm new to this.
It's not a dumb question - I just don't think anyone has ever had a look at these parts from this POV before. From what I can see, I don't think it's broken. It looks okay at the pivot stud end to me, although I really can't see much at the throwout bearing end.
Does the clutch work?
Originally Posted by MatthewMiller
(Post 1599741428)
Originally Posted by 383vett
(Post 1599741992)
Out of curiosity, does anyone know if that is too much play on the fork?
Where I talk about the slave being bent in the video, I meant to say "clutch fork isn't broken". |
Originally Posted by 1993C4LT1
(Post 1599896828)
Where I talk about the slave being bent in the video, I meant to say "clutch fork isn't broken".https://youtu.be/Q1HbCaK3OrY |
(Post 1599896891)
No, I think that's pretty normal from what I remember. It has to have a little up/down play or else it would always be putting pressure on the throwout bearing. The side-to-side play is fine, too. I really doubt any shifting roughness will be caused from a problem inside the bell housing. It's more likely to be from a hydraulic system that isn't fully bled and therefore isn't letting the clutch fully disengage, or possibly bad synchros in the gearbox.
https://cimg6.ibsrv.net/gimg/www.cor...7013aab806.jpg |
