Looking for a pin-out diagram
Anyone has a pin out diagram for the ecu on a 2014? Mine is a manual Z51 but any would help as I'm trying to locate power, ground and data pins. I have a ecu no comm issue code U0100
Try poking around on this web site. Lots of good stuff. You'll have to register with them.
GL Ron http://www.bbbind.com/tsb-wiring-diagrams-database/ |
Don’t forget to check fuses. That often gets overlooked.
Is this information found in the 2014 service manual?
I've got it in my AllData account. I'll try to upload it around lunch time.
If this helps, buy an AllData DIY account. It's cheap.
https://cimg6.ibsrv.net/gimg/www.cor...1996ae736e.png https://cimg8.ibsrv.net/gimg/www.cor...2489f130d7.png https://cimg9.ibsrv.net/gimg/www.cor...962dd70a7c.png |
Jeff it does help Thank You. I did purchased a subscription to all data. I've also found the issue with the no comm ecu.
A rusted pin #4 at connector X100. Now I need to figure out how disassemble the connector to inspect other pins that may stated to rust and to replace the bad pin. Then finding the correct pins on Mouser. |
