65 Spare Tire Carrier
Was it painted or left bare? If painted what color black? Thanks
Originally Posted by 99Silverbullet
(Post 1599713788)
Can’t say if the later ones were the same. But I believe so. |
Yep want to know what the 65 year model was. Thanks
(Post 1599713929)
Ok thank you
The '66 looks to be all natural fiberglass as well, but a darker shade of gray/black fiberglass than the '63 & '64.
https://cimg7.ibsrv.net/gimg/www.cor...ef14178f5e.jpg https://cimg8.ibsrv.net/gimg/www.cor...098349bce9.jpg Good luck... GUSTO |
Sweet Jesus Gusto, that's one incredibly clean underside. Ever drive it? LOL
Originally Posted by Sullyvette
(Post 1599720946)
https://cimg4.ibsrv.net/gimg/www.cor...40d3af50de.jpg It was listed back in December 2018 on BAT where it was bid to $100,000 but didn't reach reserve. It is such a great looking car that I saved some of the pictures for reference purposes. It's an L72, 4-speed out of Yorba Linda, California and was refurbished in 2008. GUSTO |
After taking my off the shelf and taking it apart, notice the upper tub had damage where the lid sits. Thought i could reglass that area/patch it but decided to buy a new one from a vendor.
I received the new one yesterday....Why doesn't these repops come with the holes already drilled out? Is this how the factory did it, just put it up in place and screwed it thru the fiberglass? |
(Post 1599737966)
This radial spare reportedly fits in the OE tub.
https://cimg9.ibsrv.net/gimg/www.cor...31cce5faf.jpeg |
Im running 17” wheels, so my “real” spare wont fit, but ive got a stock rim and tire ill be putting in the carrier
what was the purpose of this part of the v-bar?
https://cimg5.ibsrv.net/gimg/www.cor...8e91b9ebe.jpeg |
(Post 1599750707)
(Post 1599750707)
Its explained (and illustrated) on the jacking instruction placard on the underside of the jack storage compartment lid...
Originally Posted by Dave Tracy
(Post 1599751430)
You put the jack handle into it to let the tire out and to close it up. The bolt holding the the bottom lid is loosened, the bottom is lifted up and the bolt is disengaged from the lid. I just worked on mine today. It was covered with undercoating. I think it was done by the dealership. WHAT A MESS!
(Post 1599752337)
Yep same here, either a light coat of undercoat or someone sprayed it with flat black paint. I was able to get some of it off but still looks like crap. Going to try and work on it some more, Might just repaint it before I put the new v bar on.
Originally Posted by GUSTO14
(Post 1599752696)
Patrick, if it is undercoat, some mineral spirits or Naptha should remove it. If they don't, it's very likely some type of paint and you can use normal paint stripper to remove it.
Good luck... GUSTO Id rather try to keep it correct than paint over it. I thought those rivets would be a pain to remove but I literally took a tiny chisel and knocked the heads off with no damage. Thanks! |
