Backup cam not engaging when shifting reverse
Kenwood DNX893S. The other day the camera wouldn’t switch On when shifting to Reverse. I can manually turn it on in settings so cam is still getting power and working. any tips on what to check ?
Thanks |
Not sure about your Kenwood, but I know on my Pioneer there was something in the settings menu I had to turn on before mine would come on, suggest you look at your owners manual. Other than that it could be your camera activation wiring connection
:iagree: Check the "reverse gear input signal" wire (violet/white) in the back of your headunit to see if it's getting power when you engage reverse.
