1987 Corvette L98 turns over fires but won’t start
I have a 1987 z-51 corvette with a stock L98 and sometimes it will start and run just fine sometimes it will turn over fire and then die I am out of ideas on what it could be causing it I plan on driving it to college next month and I’d like for it to be more reliable I have replaced the following, MAF, TPS IAC fuel pump fuel filter oil pressure switch I’ve disabled the VATS it has all new plugs and wires I’m tired of spending money on parts that don’t fix my problem my next route would be either new injectors or Ecu any advice would be much appreciated
start with the basics - FUEL, spark , timing. have you run a fuel pressure test? do you have a FSM? BTW, quit throwing parts at the problem. :rock:
When it won't start, check your fuel pressure at the rail. Could be a Fuel pressure regulator.
Sounds like a Fuel Problem. When it wont start, spray some starting fluid in the throttle body to confirm. If it starts, it's probably not a timing or ignition related problem. Diagnose, don't guess. |
Sounds like fuel-issues. Check fuel pressure at rail first, with ignition in run but not started, then see how it behaves when you try to fire it.
Originally Posted by Joe C
(Post 1599721696)
Originally Posted by cadmaniac
(Post 1599721725)
When it does start, does it run correctly, or sound lean or rich? Another words, is is it flooded or starving for fuel when it runs?
(Post 1599722014)
Hook up pressure gauge at rail, observe pressure when running. Turn off car or let it turn off by itself, watch FP gauge reading. Should hold.
Then best to hook up a scanner and datalog it to see what the computer is seeing before replacing any further parts. |
Originally Posted by vader86
(Post 1599723521)
Parts stores scan codes, what you want to do is buy a scanner that will read OBD1. Mine is an Actron from Autozone with an adapter to let it read OBD1.
You can also buy an OBD1 cable and use DataMaster on your laptop. |
(Post 1599725895)
Put a paperclip in the top right 2 ports of the diagnostics connector and you can read the codes for free. Same codes as a tester.
Originally Posted by xrav22
(Post 1599733966)
(Post 1599735043)
He does not need to scan codes here, he needs to look at the datastream.
Just to make sure, no codes? As in Service Engine light is off? Since you replaced the MAF, I'd be surprised no codes unless you spent $600+ for the Bosche.
Originally Posted by kael
(Post 1599743008)
Then what is the code set?
(Post 1599747887)
If your O2 sensor is dead or dying it can flood the engine and make it cut off.
Replace the sensor and check its wiring, that should've been the first thing you did. |
