Continuation of Possible radio problems
Plugged speakers to operating side and they worked fine, in talking to repair guy he suggested I check the fuses before pulling the radio has anyone ever had issues with the Bose speakers that were fuse related, also I wiggled the slider bar and jiggled the other knob nothing happen
What year is your car? If it's before 84-89 I can't help much, later than that I can help narrow it down some.
Originally Posted by Klgrayson
(Post 1599726068)
Potential speaker problems
The car is a 1984 the passenger side front and back operates fine the driver side not at all time
There is a relay under the dash. I'm not sure what exactly it controls though but it sounds like you aren't getting power to the amps just on that one side. Unless both happen to have failed at the same time.
Just to be safe, since you said the passenger side works but not drivers side. You haven't inadvertently adjusted the balance all the way to the right, right? |
Originally Posted by 85WHITEZ51
(Post 1599732530)
(Post 1599732044)
