Spark plug gap suggestions.
I am swapping out TR6's for some NGK 7's. What would be a good gap for a LS2 running around 7 lbs and 100% meth at 4 psi? .30?
Originally Posted by newbC6
(Post 1599727905)
Why are you switching to a colder plug? For that level of boost and meth, I would put a stock LS9 #41-104 Iridium plug (= 6 NGK heat range) in it and forget about having to gap it. I’ve run that plug on both pump 93 + BOOSTane and 104 race gas at 12+ psi of boost with no meth and never saw any sign of KR and it idled perfectly.
Originally Posted by CI GS
(Post 1599729521)
Could a hotter plug or fouled plug cause any thing like that? Or carbon build up? ( it has 80k miles on her) |
(Post 1599731715)
Well ive developed a slight knock at and above4 psi of boost. I've had the same tune for the last two years and I noticed it this summer on 90 plus days . its tuned at 91 and ive been running 93 and tossed in some mmt to see if that would eliminate it. Im trying to avoid taking it back to the tuner at this point and wanted to see if a colder plug would eliminate it. I'm not experiencing any noticeable loss of power just a slight rattle . I was thinking either spark or maybe carbon deposits causing a hot spot. The meth is 100% and comes in at 5psi.
Could a hotter plug or fouled plug cause any thing like that? Or carbon build up? ( it has 80k miles on her) in any event going to a colder conventional plug may only make the car idle a bit tougher and foul the plugs quicker. If you did need a 7 heat range, then a TR7IX Iridium plug would be a better option than a regular plug, in my view. |
(Post 1599732209)
Okay, if you can hear knock, that’s something to be concerned about, but it’s probably not so much the plug being too hot (a TR6 is a fairly cool plug) as it is a tuning issue - either a lean tip in condition/PE not coming in early enough, too much advance at that point, etc. Can you bring the meth in earlier at say 3-4psi? That may help to cover any lean condition and/or knock from too much ignition lead.
(Post 1599732503)
I can switch it to spray at 3 (I believe) it's just a little boost switch. So bringing meth on earlier shpuldnt affect my AFR correct? No need for a re tune. I will give it a shot.
BTW: Do you have a wideband on the car? If not, it would be best if you got one and a Dashlogic and you can monitor the AFR, timing and all sorts of things, which would take the guesswork out of trying to troubleshoot issues like this. |
